Technical Rochester 2v clean using CLR
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Jun 17, 2024.
  1. Gotta fix the kids carb. Ran ok. Flooded very easily. Hard to crank at times due to flooding. A student rebuilt the carb and I traded him some paint for it. Kid did ok but just didn’t run like it should.
    Anyway. This is after an hour soak in CLR mixed 50:50 with water and a touch of dish washing liquid
    not bad for a cheap soak and mild brushing.
    Compressed air thru all holes.
    The clr mixture dissolved the gasket residue. Very little s****ing.
  2. Dave G in Gansevoort
    from Upstate NY
    Looks good. I've got 3 1/4 to clean and rebuild for a 3 deuce setup. I'm going to try Simple Green and an ultrasonic cleaner. Let's compare results when done.
    anthony myrick and bchctybob like this.
  3. This one is quick clean and go.
    I’ve used clr on bases and the iron looked like it was bead blasted.
    I’ve got 3 2gs to build coming up. I’ve thought about an ultrasonic cleaner. Those carbs need to look better than this one.
  4. Oneball
    Oneball
    What is CLR?
    anthony myrick likes this.
  5. 1952henry
    1952henry
    Calcium Lime Rust remover
    alanp561, Oneball and JohnLewis like this.
  6. dalesnyder
    dalesnyder
  7. It is a solvent sold in the US, calcium, lime, rust remover. Works pretty good on mildew too.
    alanp561 and anthony myrick like this.
  8. Dave G in Gansevoort
    from Upstate NY
    I'll have to try it on one of the bases. There's one that's a little bit rusty, not bad, but what the hey, give it a try...
  9. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I need to avoid Simple Green and Purple Magic:mad::eek:
  10. spanners
    spanners
    We have CLR in Australia as well. You should be able to get it in the UK or an equivalent product.
  11. Bird man
    Bird man
    from Milwaukee
    CLR is an acid & I would be quite leery.
    But I gotta say, that thing looks great!
  12. PackardV8
    PackardV8
    The result will depend upon the carb as much as the quality of the rebuild. In the mid-'70s, GM tried to crutch emissions while cheaping with a carb and distributor; couldn't be done, but the result was some **** running vehicles. The cure was to swap back to a 1960s carb and distributor.
    Bottom line, some Rochester 2GCs can't be made to run right with a standard rebuild.
    jack vines
  13. If you leave the body too long at 100% it tried to remove the plating on another carb I did.
    Didn’t seem to hurt anything other than the finish. Ran it for a few years.
    But I would not set any soft metals in it over night.
    this one set for about an hour with a couple scrubbings in between.
  14. Probably so. This was the best large base I could round up.
    Runs better now. Doesn’t seem to flood ……yet
    this BB:)#64 was stuck.
    The base was not very tight with its original or very old gasket. Looks like the student I got it from replaced the float. Wasn’t set though. Was close on closed. Opened up way too much.
    alanp561 likes this.
  15. Glad you have it sorted out.
    I've used Pine-sol cleaner on motorcycle carbs a few times. Left soaking for a while.
  16. Dropped these rusty pieces in the remaining clr mixture earlier this week
    just a fyi if you need to soak a rusty part
    Kinda cheap and EZ. This did remove the paint.
    I’ve soaked in mol***es before and that not removed paint, only the rust.
