Technical Rochester 4 jet
Discussion in 'The Hokey Ass Message Board' started by nastynotch347, Jul 14, 2018.
  1. nastynotch347
    nastynotch347
    I have a fresh rebuilt 4gc on my 327 and it’s flooding. Ran decent but rich before the rebuild and I’m sure everything was done correctly. Floats are set to factory spec (height and drop)but fuel dribbles from the clusters even after shutting the engine off.
  2. big duece
    big duece
    from kansas
    Fuel pressure??
  3. jimmy six
    jimmy six
    Drop the floats. The long arm sometimes bends. Carb king will answer here soon. Fuel pressure should be at 4.
  4. nastynotch347
    nastynotch347
    Wondering if I have a sticking float, I’ll probably pull it apart and see if I can blow thru the fuel inlet.
  5. nastynotch347
    nastynotch347
    Haven’t checked. Same mechanical pump from before the rebuild and it wasn’t a problem.
  6. big duece
    big duece
    from kansas
    I only mentioned that because you said it ran rich before the rebuild. Fuel pressure might be a gremlin before and after the rebuild.
    302GMC likes this.
  7. nastynotch347
    nastynotch347
    I agree with you and. its definitely worth looking into but doubtful it’s the cause of my flooding. I did find the secondary floats sticking.
  8. big duece
    big duece
    from kansas
    Sounds like your headed in the right direction, hope you get it ironed out:cool:
  9. nastynotch347
    nastynotch347
    Thanks, I sure hope so it’s driving me nuts!
  10. clunker
    clunker
    from Boston MA
  11. nastynotch347
    nastynotch347
    There good. Just dropped the floats 1/8” p&s and it ran great for a min then started dribbling again. Going to change the fuel filter, flush line and drain carb. Wondering if there’s trash keeping it open
    clunker likes this.
  12. 38Chevy454
    38Chevy454
    Sounds like needle and seat is not sealing. Float can work, but if not sealing then fuel pressure will still push fuel into the bowl.
  13. willys36
    willys36
    Ain't hot roddin' fun?!!!
    Truck64 and nastynotch347 like this.
  14. nastynotch347
    nastynotch347
    This is what I feel is happening, the screen in the carbs fuel inlet was spotless(not doing it’s job) the bowls were full of trash. I pulled the inline filter off and cranked it over with a length of fuel line in a jar, trash on bottom of jar. Installed a new inline filter and cleaned/blew out the carb for a temp fix. I plan to install another flushed tank I have. Only problem is the base gasket was damaged when removing the carb and have to wait for a replacement!
    Absolutely.....a love hate relationship!
    clunker likes this.
  15. nastynotch347
    nastynotch347
    More wasted time, reinstalled the carburetor and the same problem....only worse, fuel was FLOWING from the clusters. I’d had enough, there’s no way in hell its from trash! Installed the old N&S re set the float height and drop to factory spec and it runs like a dream! The kit was from Mike’s Carburetor Parts.
    clunker likes this.
  16. clunker
    clunker
    from Boston MA
    I’ve had problems with new accelerator pumps from kits as well, I try to keep the originals, if possible. The gaskets are the main thing, they get trashed just about every time you remove the top to adjust something.
