So lately I've been on the hunt for some Frog mouth scoops for Rochester 2G's and I can't seem to find any. I've turned Speedway upside down and I can't find any in there and that's usually where I can find stuff like that. All the ones I see are for 94's and 97's. Does anybody know where I can get some of the old Frog mouth scoops that fit a Rochester??? Thanks. Sent from my iPhone using The H.A.M.B. mobile app
Vintage Speed has these for 2Gs. 2 5/8 throat suits 94s, 97s. What about HAMBERS, O'Brien Truckers or ****ster?
The small base Rochester 2 Jet and the Holley 94/Stromberg 97 are all 2 5/8" neck. The issue with running frog mouths on a Rochester is the carb's flange for the scoop isn't tall enough for the set screw they've already drilled/tapped, but you can drill and tap a set screw or two slightly lower on the scoop to run on a Rochester. It helps to dimple the flange on the carb with a drill bit so the set screw has something to seat into.
Thanks fellas! Guess I'll be treating myself to frogmouth scoops this year! Sent from my iPhone using The H.A.M.B. mobile app
