Technical Rochester monojet carb replacement
Discussion in 'The Hokey Ass Message Board' started by Shiro, Apr 15, 2017.
  1. Shiro
    Shiro
    Alright carburetor experts, I need to simply know what carb is an upgrade from a Rochester. The Rochester I have just has too many leaking problems even after a couple rebuilds. By the way the engine is a 235.
  2. carbking
    carbking
    What is an upgrade from a Rochester B??? A leaky boot!
    Seriously, Carter offered a number of type YF carburetors specifically calibrated for the 235 with linkage specifically made to attach to the 235. Just need to know year, and vehicle (truck carbs generally have manual chokes, p***enger vehicles have automatic chokes).
    Carter YF carburetors produced for use on Chevrolet
    756s – 216 engine aftermarket 1937~1952
    787s – 216 engine aftermarket 1937~1952
    788s – 235 engine aftermarket 1950~1952
    789s – 235 engine aftermarket 1950~1952
    890s – 235 engine aftermarket manual choke (number ***igned, no production)
    891s – 235 engine aftermarket auto choke (number ***igned, no production)
    964s – 216 engine aftermarket manual choke 1937~1952
    965s – 216 engine aftermarket auto choke 1937~1952
    966s – 235 engine aftermarket auto choke 1950~1952
    967s – 235 engine aftermarket manual choke 1950~1952
    2008s – 216 engine aftermarket 1937~1952
    2046s – 206 engine aftermarket 1932~1936
    2100s – 235 engine aftermarket manual choke 1953~1956
    2101s – 235 engine aftermarket auto choke 1953~1956
    2104s – 261 engine aftermarket (number ***igned, no production)
    3055s – aftermarket (number ***igned, no production)
    3211s – 235 engine aftermarket 1957~1962
    3379s – 153 engine original equipment manual trans 1962~1966
    3402s – 153 engine original equipment auto trans 1962~1966
    3711s – 194 engine aftermarket 1962
    3760s – 230 engine (number ***igned, no production)
    3770s – 230 engine (taxi) original equipment auto transmission 1964~1965
    3771s – 230 engine (taxi) original equipment manual trans 1964~1965
    3772s – 194 engine auto transmission (number ***igned, no production) 1964
    3773s – 194 engine manual trans (number ***igned, no production) 1964
    3821s – 194 engine (van) original equipment 1964
    3946s – 194 engine aftermarket 1964~1965
    3946s – 230 engine aftermarket 1964~1965
    3975s – 230 engine (van) original equipment manual trans 1965
    3976s – 230 engine (van) original equipment auto trans 1965
    4043s – 194 engine (van) original equipment manual trans 1966
    4043s – 230 engine (van) original equipment manual trans 1966
    4044s – 194 engine (van) original equipment auto trans 1966
    4044s – 230 engine (van) original equipment auto trans 1966
    4048s – 230 engine (van) aftermarket experimental 1963~1966
    4072s – 194 engine original equipment auto trans CALIF smog 1966
    4072s – 230 engine original equipment auto trans CALIF smog 1966
    4073s – 194 engine original equipment manual trans CALIF smog 1966
    4073s – 230 engine original equipment manual trans CALIF smog 1966
    4080s – 194 engine original equipment (p***) auto trans CALIF smog 1966
    4080s – 230 engine original equipment (p***) auto trans CALIF smog 1966
    4080s – 250 engine original equipment (p***) auto trans CALIF smog 1966
    4085s – 230 engine original equipment (truck) manual trans CALIF smog 1966
    4085s – 250 engine original equipment (truck) manual trans CALIF smog 1966
    4086s – 230 engine original equipment (truck) auto trans CALIF smog 1966
    4086s – 250 engine original equipment (truck) auto trans CALIF smog 1966
    4145s – 194 engine original equipment (truck) manual trans 1965~1966
    4145s – 230 engine original equipment (truck) manual trans 1965~1966
    4202s – 250 engine (taxi) original equipment auto trans 1966
    4203s – 250 engine (taxi) original equipment manual trans 1966
    4278s – (export to India)
    4339s – 194 engine aftermarket 1963~1967
    4339s – 230 engine aftermarket 1963~1967
    4339s – 250 engine aftermarket 1963~1967
    4367s – 230 engine original equipment manual trans CALIF smog 1967
    4367s – 250 engine original equipment manual trans CALIF smog 1967
    4368s – 194 engine original equipment auto trans CALIF smog 1967
    4368s – 230 engine original equipment auto trans CALIF smog 1967
    4368s – 250 engine original equipment auto trans CALIF smog 1967
    4369s – 230 engine original equipment (truck) manual trans CALIF smog 1967
    4369s – 250 engine original equipment (truck) manual trans CALIF smog 1967
    4370s – 230 engine original equipment (truck) auto trans CALIF smog 1967
    4370s – 250 engine original equipment (truck) auto trans CALIF smog 1967
    4371s – 230 engine original equipment (truck) manual trans CALIF smog 1967
    4371s – 250 engine original equipment (truck) manual trans CALIF smog 1967
    4371s – 292 engine original equipment (truck) manual trans CALIF smog 1967
    4372s – 250 engine original equipment (truck) auto trans CALIF smog 1967
    4373s – 153 engine aftermarket manual trans 1963~1967
    4374s – 153 engine aftermarket auto trans 1963~1967
    4375s – 230 engine original equipment (truck) manual trans 1967
    4375s – 250 engine original equipment (truck) manual trans 1967
    4376s – 230 engine original equipment (truck) auto trans 1967
    4376s – 250 engine original equipment (truck) auto trans 1967
    4377s – 250 engine original equipment (taxi) manual trans CALIF smog 1967
    4378s – 250 engine original equipment (taxi) auto trans CALIF smog 1967
    4387s – 194 engine original equipment (truck) manual trans CALIF smog 1967
    4480s – 230 engine aftermarket (all Federal) 1963~1967
    4480s – 250 engine aftermarket (all Federal) 1963~1967
    4492s – 194 engine aftermarket 1962
    6213s – number ***igned no production
    Jon.
  3. Shiro
    Shiro
    Thanks a bunch Jon! I picked up an Autoline monojet and installed it with very little modifications. The only problem I have now is getting the gas from spitting out of the carburetor while trying to start the engine. Any suggestions????
