Technical Rocker Arm Screw Height
Discussion in 'The Hokey Ass Message Board' started by Truck64, Nov 12, 2017.
  1. Truck64
    Truck64
    from Ioway
    So I finished up with replacing the valve springs and rebuilding rocker arm ***emblies on the Y block, all new rockers and rocker shafts, pushrods &c. Lash is set .019"
    Have read all screws should be about the same height. What is the issue when they are not. Can't be anything good - cam lobe/lifter getting lunched?
  2. Rocky
    Rocky
    Classified Editor
    Looks like the adjusting screw has been screwed down quite a ways and then backed off. Maybe accidentally screwed down really tight, wiping a lobe off? Also might check to see of the rocker arm has worn into the rocker shaft or maybe a pushrod is bending?
    Truck64 likes this.
  3. Truck64
    Truck64
    from Ioway
    It's a new rocker, never been installed. They are all new rockers. New rocker shafts, etc. I backed 'em all off a bit before installing the rocker ***emblies. The screw might have looked like that when I got it. Maybe somebody dinked with it in the last 50 years, but the ball and rocker are definitely NOS. Pushrods, rocker shafts, rockers all new hardware. Everything.
    I've since ran it up for about 20 minutes to break in the new valve springs and drove it about a half hour cruising and it runs better than ever. Wouldn't a bad lobe or lifter cause it to run real bad? Runs real smooth now. Pulls steady high vacuum, etc.
  4. jimmy six
    jimmy six
    Are all the push rods the same length?
    Truck64 likes this.
  5. Truck64
    Truck64
    from Ioway
    IMG_0060.JPG Here's what the plugs looked like, removed them to replace valve springs. The low screw is #6 exhaust if I'm thinking right.
  6. Truck64
    Truck64
    from Ioway
    Yes, 8.25 iirc. Elgin PR-71S
  7. tb33anda3rd
    tb33anda3rd
    recent valve job?
    blowby and Truck64 like this.
  8. Rex_A_Lott
    Rex_A_Lott
    A bad cam lobe would cause it to run bad. If it gets bad enough it will spit back through the carb when you get on it.
    I would put a dial indicator on it at the valve itself, roll it through by hand, and compare it to a couple of others. That will show you if the cam lobe is worn.
    What you might be seeing is just the manufacturing tolerance stack of that combination of parts. I remember reading where Smokey built a checking fixture and went through a pile of rocker arms to find 16 best ones. Good luck
    egads and Truck64 like this.
  9. egads
    egads
    Hard to see but looks like that rocker arm is a different number? Several different rockers for a y.
    Truck64 and Rex_A_Lott like this.
  10. Truck64
    Truck64
    from Ioway
    The rockers were purchased in three lots, a mish mash of NOS on that auction site. They are getting kind of spendy otherwise, my avg. price ended up at $7 per, which I thought was pretty good. These are all 1.43 ratio rockers, regardless of markings. 5751066 is OEM markings, service replacements didn't have markings. The 1.54 ratio rockers are shorter on one side and marked different, ECG 6564. Any valve work itself would have been done long ago. The springs needed shimming, but the valve stem tips were even with a steel rule placed across?
    Checking valve lift against the others sounds like a good plan.
  11. Happydaze
    Happydaze
    Not trying to be a wise *** but the rockers can't all be in the same position at the same time, unless there's something very wrong! Admittedly however there does seem to be more adjustment 'used' on one of them. I'd be rechecking the lash first and then measuring the lift. Pics from a better angle might help too - hard to see if the pushrod to the one in question is raised or not.
    Chris
  12. egads
    egads
    True, might be all 1.43 but the threaded boss on the 575 looks thicker than the others( no step at threaded boss? )
    Truck64 likes this.
  13. blowby
    blowby
    from Nicasio Ca
    From the photo the rocker on the valve that is open looks thicker where the adjuster screws in.
    Truck64 likes this.
  14. Truck64
    Truck64
    from Ioway
    IMG_0066.JPG See, that's why you guys get paid the big bucks, for pointing stuff like that out. 7 of the rockers were different in finish and might have been OEM, three looked to have some sort of coating. Some looked almost as if they'd been honed and rocker tips resurfaced. So I put all of one kind on the intakes and the others on exhaust, or that was the plan anyway. Y blocks are weird in that it's EIIEEIIE iirc.
  15. Rex_A_Lott
    Rex_A_Lott
    Glad you got it figured out.:)
    egads likes this.
  16. jimmy six
    jimmy six
    Just like a Chev SB.
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Port location or weird?
    egads likes this.
