Rocket 350/454 specs?
Discussion in 'The Hokey Ass Message Board' started by scratchit, Dec 15, 2006.
  1. scratchit
    scratchit
    Hey all,
    I'm trying to find HP specs on a 71 rocket 350 from an olds cutl*** and a Rocket 454 from a 66 Olds Delta 88 but can't find anything!?!?
    Any info appreciated.
    Thanks
  2. squirrel
    71 olds 350 was 240 hp with 2bbl carb, 260 w 4bbl
    66 olds 425 was 310 to 375 hp, the 454 is a chevy engine
  3. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    probably because the 454 from the Delta is either a 425 or a 455 (probably the 425- which is a killer motor)
    the rocket 350 is just that- an olds 350.
    Check out 442.com. they got specs.
  4. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    damn that squirrel is quick!
  5. squirrel
    I have a usb port on my old car books, you know....
  6. Oldsmobile did make a 454" motor....It never was installed on production cars,just a counter parts block.
    I thad the cam bore raised to acommodate the additional crankstroke.
    It has a Rocket emblem cast on each side of the block and was capable of .125 overbores....Originally sold new for 2700.00
    And -PLUS- it was a small block too!
  7. squirrel
    here's why, look at all the useful info I have at my fingertips when I sit at the computer!
  8. erock805
    erock805
    Get right outa town...what year was this?
  9. jetmek
    jetmek
    as a fwiw post, i built a 425 some years back for a 75 gutl*** i had, it made good low end but wouldnt go much past 4500 and with 10.5 cr had lots of spark knock troubles on anything but 93 and up gas
  10. erock805
    erock805
    Sqrl u kill me! Somehow that is exactly how I thought your office would be like, not that I think of you often or anything...
  11. I believe during the '90s they introduced that block,primarily a racing effort,it was actually an Olds labeled block with Chevy SB dimensions externally....
    Frankly, I never saw one in anything.
    Do not know if still available....
    I suppose they were in pro stocks/dragracing.....
