Technical ROCKET RACING/AMERICAN RACING WHEELS???
Discussion in 'Traditional Hot Rods' started by 2FORCEFULL, Mar 24, 2024.
  1. ALLDONE
    ALLDONE
    not my car,.. can't post my car till i change the wheels
  2. ALLDONE
    ALLDONE
    here's the car...
    lotta chrome on the car, all steel,...stock dash... but saddle tanks..
    Texas57, -Brent-, papajohn and 5 others like this.
  3. flamedabone
    flamedabone
    Nice little car. She would look great in a set of bias ply black walls with '40 Ford wheels and caps.
    -Abone.
  4. ALLDONE
    ALLDONE
    16's ???? bigs and littles , or all the same size??? thanks for the post...
  5. Rynothealbino
    Rynothealbino
    7.50-16 on the rear and something like a 5.50 on the front would look pretty mean.
    Old school bigs and littles.
    Similar to your current setup of 235's and 185' just skinnier and more vintage looking.
    What do you want, a 40's to 50's era built car, or something that would have been built in the 60's or later?
    -Brent- likes this.
  6. bobkatrods
    bobkatrods
    from aledo tx
    Only issue I see with them is the lip on Vintage TQ have a machined finish versus polished
  7. flamedabone
    flamedabone
    Something like this.
    7.10X16 rear, 5.25X16 front. (all 4 wheels are 16X4) Black or whitewall works on your car and there are a pretty good handful of wheel color choices that fit.
    -Abone.
  8. ALLDONE
    ALLDONE
    heres my Cdan
    Deuces likes this.
  9. ALLDONE
    ALLDONE
    it's too far gone to be pre war..just a hotrod I guess..
  10. ALLDONE
    ALLDONE
    I was thinking that with the car all white, white walls would be a little too much white????? and with the car having so much chrome... stick with the chrome look...I ordered 15's ,.. blackwall tires ,.. should get them mon-tues... if they don't look right I don't have to keep them, I can get something different...so will see
  11. Martein
    Martein
    Sorry, a bit off tpopic
    @2FORCEFULL , you mentioned there were saddletanks fitted?
    Where is the fillercap fitted? Usually it's on the side aprons right?
    Cheers, Martein
  12. ALLDONE
    ALLDONE
    I never get lucky enough for usual... they're in the wheel wells... so the rear has to be up enough to put gas in...probley gonna take it to the shop and put new tubing with 2 to1 filler at the rear of the car so you can fill both tanks at once... I've had this set up before , PITA.. you put gas in one side , then have to turn around to fuel the other side... once I get it up on the rack, might figure out a way to put a single 16 or so tank..
  13. ALLDONE
    ALLDONE
    got the new steering wheel on..
    Deuces likes this.
  14. ALLDONE
    ALLDONE
    and the wheels and tires...
  15. ALLDONE
    ALLDONE
    got them tucked in the fender sides
    gnichols, Texas57, Just Gary and 5 others like this.
  16. Years ago, there was a company that used the original fill neck on the cowl and used tubing down each cowl side to fill the saddle tanks. Another company used separate fills through the aprons.
  17. ALLDONE
    ALLDONE
    Yeah, I gotta figure something out... thanks for the post
  18. WAYNE WILLEY
    WAYNE WILLEY
    Yeah, a LOT of money. Bad*** looking coupe BTW.
  19. Grumpy ole A
    Grumpy ole A
    I like your chrome five spokes with the black walls.
    2FORCEFULL likes this.
  20. ALLDONE
    ALLDONE
    took the back window off, and the front and rear bumpers.... and waiting on a 5'' water pump riser to get the fan in the middle of the radiator.also lowered the rear 2''..should be on the road soon...
    Just Gary likes this.
