Rockstars with TorqueWrenches-Starter Trouble
Discussion in 'The Hokey Ass Message Board' started by RoadSavage, Dec 25, 2003.
  1. RoadSavage
    RoadSavage
    So.. I go out to start the 54 and hit the key. Starter turns over fine. I let go of the key to give it a few pumps and the starter is still turning over. Turn the key to the off position and the starter is still turning over. Turn the key to the lock position and take it out of the ignition... yup, the starter is still cranking. Pulled the battery cable off before the 235 fired up. Tried this a couple more times with the same results. Should I look for the problem at the ignition switch or the solenoid?
  2. candyman
    candyman
    What you should do marty... is either chop the top 5 inches... or sell that fucker to me! [​IMG] Merry Christmas man...
  3. skipperman
    skipperman
    first...wack it with a BFH (see if it lets go---you can also turn the motor BACKWARDS by hand)...next take it out and lube the bendix...sounds like it's hangin' up due to lack of lube...last--solenoid may be stuck "on".......... also...make sure the wire that energizes the solenoid goes OFF when ya let go of the key...
    Jersey Skip
  4. low voltage problem, check all the connections (cables, battery), check battery voltage you might have to check starter and sol inside. 6v are hit more with low voltage problems because of the high amp demand. make sure battery is in a good state of charge.
