rodsville open drive quickchange
Discussion in 'The Hokey Ass Message Board' started by silent rick, May 22, 2013.
  1. silent rick
    silent rick
    who sells them? any alliance deals available?
  2. **** Spadaro here does
  3. So-Cal Speed Sacramento
    Alliance Vendor
    from Sacramento
    hot rod works out of idaho does. i'm pretty sure they're an Alliance vendor as well.
  4. silent rick
    silent rick
    i'll have to call ****, his website lists the open drive version a couple hundred bucks cheaper than the torque tube model. usually, it's the other way around.
  5. silent rick
    silent rick
    they're out of stock and they don't discount that quickchange
  6. brigrat
    brigrat
    from Wa.St.
    Try "Frames" here on the HAMB he may have something that interest you...................
    kidcampbell71 likes this.
  7. banjorear
    banjorear
    Did he take over Wilson Welding's Ford banjo conversations?
  8. flthd31
    flthd31
  9. cracker head
    cracker head
    No.
  10. ChuckleHead_Al
    ChuckleHead_Al
    The guy that did take over that conversion, well don't go that route. I created a post about it to warn people about it.
  11. thunderbirdesq
    thunderbirdesq
    yeah, X2 on that...:(
    **** Spadaro carries winters units, the Rodsville is entirely different, a beefed up early halibrand. Call Sig, the proprietor.
  12. silent rick
    silent rick
    what exactly are the differences? just the added strength? they both use the internals from a 40 banjo? or does the winters require it's own differential?
  13. ago
    ago
    from pgh. pa.
    I believe Winters uses there own ring and pinion and original Ford diff.
    Ago
  14. thunderbirdesq
    thunderbirdesq
    The rodsville unit will accept vintage halibrand parts and LOOKS like the real deal. The winters unit has no pinion support like a model a or early '32 rear end, and the rear cover has more bolts in it, I've never used the winters before so I can't comment on its strength, etc...
  15. brigrat
    brigrat
    from Wa.St.
    The instructions for the Winters says "This unit not intended for compe***ion application or high horsepower vehicles."
    Edit; These instructions and warning were about the Winters/Spadaro Q/C, sorry for any confusion.....................
  16. The Winters V8 Quickchange has a very heavy duty Pinion Support, and I was told by Beaver Winters that it will take 500 HP as long as you are not side stepping the clutch with slicks on the drag strip.
    The rear case is also 1" shorter that the Halibrand, so you do not have to notch the gas tank in a 32 Ford application.
    Other than the 10 bolt rear cover it is almost identical to a Halibrand, but stronger.
  17. thunderbirdesq
    thunderbirdesq
    Sure looks like no pinion support to me... maybe they make them differently for spadaro? Hell, maybe they're just winters look-a-likes. Hopefully **** can chime in and clear this up? Like I said, I've never used one personally.
  18. thunderbirdesq
    thunderbirdesq
  19. 28rpu
    28rpu
    Winters has different versions of their quick changes. The one Spadaro sells is the one without the pinion support. It uses the Ford V8 differential and stock axles. They supply the ring and pinion. It's no better than a Ford banjo rear end for strength. As shown above the Rodsville is a clone of the Halibrand and is a very nice unit. The Winters 3605 will accept V8 housings, has a supported pinion and uses their wedgelock differential in 28 or 31 spline. An axle conversion is needed for the V8 housings to use this center section. Hope this helps. Nick
  20. flthd31
    flthd31
    If your reading this thread, Here's a link to an old thread from 2005 that you should read.
    http://www.jalopyjournal.com/forum/showthread.php?t=68124
    On page two, down on post #31, Cyclone Kevin calls out **** Spadaro for not having any pinion support in his version of the Winters Quickchange.
    **** responds a couple of post down on his reasoning.
    It's a great discussion thread.
  21. ChuckleHead_Al
    ChuckleHead_Al
    Does cyclone kevin have a website to sell his quickchange? I was wondering because doing a google search the only place that sold the quickchange was www.hotrodworks.com
  22. what about dutchman???...looks like a sweet quickchange...
