Projects Roll bars in an Impala
Discussion in 'The Hokey Ass Message Board' started by steamer, Sep 13, 2011.
  1. steamer
    steamer
    Is anyone running a vintage Impala? I want to install a roll bar in mine and need some input. The Impala frame is an X and I'm baffled on what to do. I have a 63......any advice?
  2. slammed
    slammed
    Adding square tubing to the frame. Like outriggers. A good question, and no doubt some racers will have some detailed pix of there rides. What is the motor combo for your Avatar?
  3. steamer
    steamer
    327, I'm trying to be period correct for a 63.
  4. 1971BB427
    1971BB427
    from Oregon
  5. Jack60
    Jack60
    from Maryland
    I bought a S&W 6 point cage for a 62 Impala, it never got put in. Are you looking to buy one......?
  6. novas4life
    novas4life
    from vnc,wa
    I know you said "period correct".But with that being said,to be NHRA legal it needs to be at least an 8 pt bar and since your car is a full frame car,it needs to be welded to the frame or outriggers attached to the frame.
    An 8 pt will clear you to 10.00.Also,there are certain demensions that need to be within spec also for the placement of the bars.
    Brandon
  7. slammed
    slammed
    Motor correct. Is this car aiming to run at the NHRA tracks? Otherwise, conforming to the powers that be is moot.
  8. 71buickfreak
    71buickfreak
    from Oklahoma
    Outriggers is how it is done on an Xframe. It all depends on the tracks your frequent. I have 3 within an hour frome me. One is an NHRA-certified track and the tech there is brutal. One of the small tracks to the north of me doesn't even run tech most of the time.
  9. steamer
    steamer
    Guy's, let's not get nuts.....I might take it to Island Dragway to make a few passes. I don't plan on running competitively. this is just for fun.....Thanks for the info, I would like to see some pictures.
  10. 296moon
    296moon
    from england
    Why not just make a cage/hoop for you and your seat
  11. steamer
    steamer
    I sorta dig that Idea myself. Thanks.
  12. 1320/150
    1320/150
    Actually you only need five points to clear you for 10.00 e.t.. The side bar on the passenger side is not manditory. Most people put it in for symmetry,and it is stronger. As far as putting in a hoop around yourself I wouldn't bother. Its gonna be the same amount of work,and you never know you might be in the 11.50 range where you need this roll bar. If your faster than 11.50 on any sanctioned track in the land,your gonna be required to have this roll bar N.H.R.A or not.... Personally if I was you I would pick up a current rule book and look through it before you cut any holes!!!
  13. Junior Stock
    Junior Stock
    Some guy's did'nt run a roll bar back then.
  14. 61 chevy
    61 chevy
    look up dyno don ,see what he ran back then
  15. Junior Stock
    Junior Stock
    nada
  16. Junior Stock
    Junior Stock
    Sorry for not being of help. See you have 60 Gasser on your friend list. Drop him a PM. Sure he'll be happy to help.
