ROLL DOWN rear window on model A
Discussion in 'The Hokey Ass Message Board' started by c_illes, Sep 1, 2012.
  1. c_illes
    c_illes
    i want to make my truck have a roll down rear window, i have never seen it before and looks like a rare option do any of you guys have any pictures? possible of the inner workings.
    did they have problems with letting water into the cab?, i wonder how well it seals off.
    I was thinking of grafting a door onto the back so it would roll and have the proper weather stripping.
    any ideas??
  2. dudley32
    dudley32
    coupes had 'em...they came with a drain...
  3. c_illes
    c_illes
    I found another thread on here about it, but there really isnt any details on how it drains,. you must have to drill drain holes on the sheet metal below the window
  4. Rusty O'Toole
    Rusty O'Toole
    I think they came on rumble seat coupes. If the windshield opened too you had some cool ventilation for hot summer days.
    You could get some gl*** cut and use any kind of windup mechanism you like, including electric. Also, make some kind of drain pan to drain off any leakage under the car. Like a pan with a pipe thru the floor.
  5. daddio211
    daddio211
    I don't think any A's had roll down back windows, I do know they had them in '32 but not pickups. No reason you couldn't make your own though, just like the door gl***. Weld in a small V under the window and tracks to catch moisture, cap the ends, and install a drain tube to the bottom.
  6. jimbousman
    jimbousman
  7. c_illes
    c_illes
    I know people must be buying that kit but its pretty expensive , anyone mkae their own
  8. chopt top kid
    chopt top kid
    Here's a couple pic's...
  9. 325w
    325w
    the coupes used a roll down set up. if you use a original set up you will loose some room for the seat to set back in.The coupe roll down set up went behind the package tray
  10. gnichols
    gnichols
    from Tampa, FL
    Inserting just what you need from a door window ***embly sounds like a good plan if cheaper than used / repop units. That would probably require some sort box to hide / protect the gl***, channels and regulator, hold the crank handle, and collect / drain water just like a door does. The smaller the window (chop top?), the shallower the enclosure, too. Gary
  11. terrarodder
    terrarodder
    from EASTERN PA
    They were put in rumble seat coupes so the driver and those in the back could talk to each other.
  12. kyvetteman
    kyvetteman
    I had a stock '30 Coupe that had one. Neat little idea.
  13. 56don
    56don
    No bigger than a back window in a pickup is, you wouldn't really need a roll up mechanism. You could just adapt some kind of lever setup whereby you can raise it up and lock it into place or let it down to bottom out in a drain rail.Not much room at all behind you in a pickup cab.
  14. daddio211
    daddio211
    I learned something new! Good to know some were made.
    Sent from my DROID device using the TJJ mobile app
