Roll on primer?
Discussion in 'The Hokey Ass Message Board' started by papajohn, Sep 8, 2012.
  1. papajohn
    papajohn
    Anyone try it? I was watching an o/t show this morning (trucks) and they were using "all u need" urethane primer saying you could brush or roll it on and you didnt need a respirator. Seems like you would get more on the car and not lose any to atomization so thats a plus. You're going to sand it smoothe anyways. Crazy?
  2. punisher7
    punisher7
    Sounds like a lot of sanding to me
  3. Do a search, been discussed a few times.
  4. papajohn
    papajohn
    I've seen the posts about rolled and brushed paint jobs, but I was thinking strictly about urethane primer. (but, no, I didn't actually search it, sorry if I'm re-posting a topic)
  5. Smokin' Joe
    Smokin' Joe
    Been doing it for years. Helps to get quick build without such a mess. I use it with my polyester a lot. Just don't let polyester sit too long before blocking it, it's like sanding concrete.
  6. I wouldnt know if you use primer with roll on,,,,, I use Speed Stick :D
  7. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    It's all about the "application" method. You can Spray, Roll, Brush, Squeege, (yes even
    Squeege) primer. Which ever "application" method works for you and your available applicator ! ! ! You do need to keep in mind that the film build has to be controlled for
    proper curing to take place. There is nothing wrong with applying Urethane Primer with a roller. They even make a pan and roller (approx.8") just for Urethane Primers.
    Happy Rolling ( No, not Happy Smoke ).
    VR&C.
  8. 1937chevyman
    1937chevyman
    get lots of sandpaper
  9. Mr48chev
    When I bought the 48 it was dark green but had a brushed on primer job under the green that you could see the brush marks through the green on. I don't know what kind of primer it was but it was some tough sanding stuff.
    A lot of boats including some real expensive ones are repainted by hand with a roller followed by a brush called Rolling and tipping. It pretty well takes two people who know what they are doing to get it right but you can get some great results.
    Here is the link to one article
    http://www.boatus.com/boattech/casey/rolling-tipping.asp
    This link has some short videos that show technique.
    http://www.sailingmates.com/paint fiberglass sailboats.htm
  10. flatmotor40
    flatmotor40
    from georgia
    At $250 gallon Wow for primer
  11. With the new national law regarding applying coatings "on the floor" many shops have gone to rolling primer on. PPG has been showing it for at least 10 years. It allows shops a "out" because it's not atomized they can get away with it. If done right, with the right rollers ( not home depot stuff ) it will work and build. You sand primer prior to sealer or base anyway, you may just sand a little more now.
  12. jmpowie
    jmpowie
    I used a brush to prime my 29. I used epoxy to keep the car from flash rusting. It was easier to paint a door with a brush than mixing a batch of paint and clean the gun to do a door or cowl. Now that the car is ready for paint I will spray a sandable primer and block sand the car.
  13. Nekronomicon
    Nekronomicon
    Yeah done it a few times, great for small areas when you dont want to mask up the car and cover everything else around you. Like the others said, leave plenty of times between coats and allow it to flash off like when you spray it
