Anyone have some pics of steel rods with rolled rear pans. I am considering it and would like to know if it is a ton of work. BC
i think they trap alot of air from under the car....unless your running a full belly pan i would stay away from it whats wrong with your car now? depending on what time period your working towards...how about a knerf bar or a bumper of some sort....or frame horns extended with a spreader bar? and maybe dual pipes out the back? but if your gona do one....they arent alot of work...you can make the corners first...then the center and weld it...saves trying to keep a big flat area, flat good luck in any case Zach
