Projects Roller Rocker sweep
Discussion in 'The Hokey Ass Message Board' started by PeggySue, Aug 10, 2026.
  1. PeggySue
    PeggySue
    Installed Edelbrock E-street Aluminum heads on a SBF , Scorpion rockers, flat tappet cam, hydraulic lifters mild cam 4.80 lift. With length checker came up with 7.025 pushrod length. Run the motor and rechecked sweep mark its 1/3 on the intake side to 2/3 exhaust side. Is this OK or should I go with 7" pushrod?
  2. I only see one picture and if that is the sweep, it is fine.
    PeggySue likes this.
  3. PeggySue
    PeggySue
    Thanks couple more pictures, I just checked one valve stem. Sweep is about .40
  4. From what I'm seeing, the sweep is that shiny line in the middle? If so, then it looks fine to me. You have a low-lift cam, so the sweep line is pretty narrow - all good.
    seb fontana, PeggySue and SS327 like this.
  5. PeggySue
    PeggySue
    Thanks ,yes shiny part sweep line, gauged it about .40. From what I have read to be under .60
  6. saltflats
    saltflats
    from Missouri
    What does the rocker are looking like at half the valve lift?
  7. PeggySue
    PeggySue
    You mean angle to the head? looks close to 90 degrees, roller looks close to center of valve stem as good as I can see. Picture at 1/2 lift
  8. saltflats
    saltflats
    from Missouri
    Could tell more from a picture looking straight at the rocker.
  9. PeggySue
    PeggySue
    The best I can do
  10. gimpyshotrods
    gimpyshotrods
    Set the lash and drive it for a while. Rest the lash and drive it until something breaks.
    There are may possible explanations for this, and none are worth chasing.
    ***uming this is a stock Iron block, it could very well be a casting or machining variance. Given that that block already lived a good long life, and was still in good enough shape for you to continue to use it, then whatever it is, you ought not worry about it.
    PeggySue, lostone and alanp561 like this.
  11. yellow dog
    yellow dog
    from san diego
  12. saltflats
    saltflats
    from Missouri
    I would say from the sweep pattern you will be good.
    gimpyshotrods, PeggySue and lostone like this.
  13. Joe H
    Joe H
    Put the cam at 1/2 lift and see where the rocker sets. You are really close so you might not see much difference. At 1/2 lift, the roller should be dead center of the valve stem.
  14. PeggySue
    PeggySue
    7" being there Edelbrock E-street aluminum heads not stock heads. Did check pushrod length with a length checker tool, thats how I arrived at he 7.025. Engine has been run some that's the sweep mark you see.
  15. PeggySue
    PeggySue
    That's what the side picture is of rocker 1/2 lift and roller looks to be pretty much centered
  16. Ericnova72
    Ericnova72
    from Michigan
    The tutorial for correct mid-lift geometry.
    To me it looks like you need to be longer PeggySue, I'd want to see what happens with a 7.050 ot 7.075" length. If pattern moves outboard a hair but gets narrower that is still better. Sweep is what wears parts out.
    PeggySue and 9200 IH like this.
  17. PeggySue
    PeggySue
    If you look at the first picture I posted of the valve stem sweep mark which I had run the engine for 3-4 minutes making a sweep mark the mark starts 1/3 on the intake side sweeping 2/3 past center toward exhaust side. going with a longer pushrod would move the sweep mark even more past center toward exhaust side. Using a gauge the sweep is .40 which I understand should be under .60
  18. jimmy six
    jimmy six
    If you ran a shorter push rod (how much I don’t know) you could probably get it dead center. For a street engine it’s fine and looks side to side pretty centered. Personally I used 10* keepers so I can use lash caps…. but that’s just me.
  19. lostone
    lostone
    from kansas
    I'm sorry but at .040 and it's location I'd quite worrying about it and run it unless you plan on keeping this motor above 6500 rpm all the time.
    I doubt very many small blocks back in the day came that close from the factory and look how many hard miles and abuse were put on a lot of them....
    PeggySue and gimpyshotrods like this.
  20. PeggySue
    PeggySue
    I guess I don't understand your first comment about .40 and location - worrying-run it - keep about 6500 rpm, quite confussing
  21. gimpyshotrods
    gimpyshotrods
    He's saying that the location and sweep are just fine, and to quit worrying.
    The location and sweep are just fine, even at 0.060"
    The comment about keeping it at 6500rpm, as one might with a dedicated race car, is related to what happens to valve springs and valvetrain at that speed.
    Valvetrain velocity at that engine speed can result in valves opening farther than is intended and induced by cam/lifter movement. Valve springs can develop harmonic oscillation, vibration and twisting, which can result in all manner of damaging conditions.
    The Laws of Physics being what they are (not negotiable), there is always some of this happening in every machine.
    You do not have an engine set up, or intended to operate at a speed that would exacerbate these conditions. There is no need to worry.
  22. saltflats
    saltflats
    from Missouri
    Those slow motion videos of the valve springs at work are crazy. I remember Grumpy saying he ran the factory nylon cam gear to help keep vibration from traveling through out the engine.
    gimpyshotrods and 427 sleeper like this.
  23. PeggySue
    PeggySue
    Thanks I though that was the intent but the statement seemed to go back and forth. OK reread what he posted I miss read sorry
  24. gimpyshotrods
    gimpyshotrods
    No worries!
  25. jimmy six
    jimmy six
    He wasn’t the only one!
    saltflats and 427 sleeper like this.
