rolling those fender lips
Discussion in 'The Hokey Ass Message Board' started by lowrodderchev, Oct 15, 2011.
  1. hey fellas i finally got my subframe in my 57 chevy truck. but now that shes all pretty nice and low tires are rubbing on the fender lip. im sure theres alot of people that have had that problem. any ideas or wisdom you guys can p*** along? cut the lip, roll it back with a baseball bat, etc. thanx
  2. VoodooTwin
    VoodooTwin
    from Noo Yawk
    My 55.2 Chevy truck sits ULTRA low, yet my tires don't rub. Are your wheel offsets causing the issue?
  3. A hardwood bat works quite well, work it slowly in stages (kind of like torquing a cylinder head - 1/3 of your fold all the way around, followed by 2/3s, etc.). If your paint is nice, make sure you warm the edge a little with a heat gun to avoid cracking it. Good luck!
  4. Hemiman 426
    Hemiman 426
    from Tulsa, Ok.
    Eastwood, for one, makes a fender lip roller tool. Used them on fox body stangs with very good success. Check around and see if someone in your area has one to rent out.
    Bill
  5. My 55.2 Chevy truck sits ULTRA low, yet my tires don't rub. Are your wheel offsets causing the issue?[/QUOTE]
    heres a pic what do you think? they seem pretty shallow to me.[​IMG]
  6. ok dam pic didnt go thru i'm running ralley wheels though. i'm tight on money so eastwoods out of the question. i'll probalay try the baseball bat method.
  7. 63comet
    63comet
    Anyone got any further info on this technique? Will it work with straight topped fender openings like on my car?
    I watched some YouTube vidyas but it was all on newer cars with radius shaped fenders already.
    I'm trying to find a bit of extra clearance for my back tires. I thought they'd fit! And tried rolling the fenders with an aluminum the but kept getting hung up at the transition from curve to flat a the top of the opening.
    If'n I had the horsepower to back it up I'd just radius the *******s, but that's a project for another day.
  8. 1971BB427
    1971BB427
    from Oregon
    Even pretty squared edge lips can be rolled, but you'll need to raise the body to get the correct angle on an aluminum bat, or real roller. If you try to roll the edge when it sits at stock height you wont be able to hold the bat angle well. I jack the car up so the lip is just near the top of the tire, and then put a 4x4 block of wood between axle and body/frame to hold it there. Then you can put the car back on the ground and get a helper to slowly roll the car as you roll the bat and the edge. Take your time, and get the height correct, and it will roll under fine.
  9. 63comet
    63comet
    I wouldn't damage anything blocking spring to subframe would I? My brake lines run across right at the top of the axle there above the shackles. The cylinder outlets come straight out.
    I figured patience was the biggest part of the process. Have to find the right helper that won't get bored with the shouts of "FORWARD! HOLD! REVERSE! HOLD!"
  10. junk yard kid
    junk yard kid
    I used a hammer handle got it in a little and then turned the hammer head like a big t handle. I could look at it as i rolled it. Took several p***es to get the waves out.
  11. Atwater Mike
    Atwater Mike
    I tried that one on my '55 F100. Might as well have tried it on a Sherman Tank.
    This baby is thick-skinned as an ex wife!
  12. lowriding 'lane
    lowriding 'lane
    On my bagged cars I'll usually cut the fender lip off and take some 1/4" steel rod, take some time and bend it exactly the shape of your wheel well opening, and weld it in on the back side where the lip used to be. You can do it in sections if you have to. Makes for a nice, round edge that won't rub your tires.
  13. 1971BB427
    1971BB427
    from Oregon
    You can easily cut a notch in a 4x4 to avoid crushing the lines, and straddle them. A patient helper is always a must. You can also get thengs started to roll by making a tool that will bend the edge a little before starting with a roller. Take a piece of 1/4" flatbar and use a hacksaw to cut a notch in it from one side. Make the notch wide enough to slip over the inside lip of your wheelwell. Then you can slip it over and gently pry the edge up a llittle at a time. Just work your way along until it's all bent up. Then if it needs more apply the roller.
    Or just hack the wheelwells and make a new lip like I did on my Falcon! ;)
  14. swade41
    swade41
    from Buffalo,NY
    What subframe did you use ? I did the 79 camaro swap on my old 58 and used skinny rims. I would think you could just use channel locks and just work it a little at a time, pain in the *** but it will work.
    The new owner raised it up a bit but still kinda low
  15. 63comet
    63comet
    Me? I'm just referring to the stubby rails back there as its a unibody ch***is. Ch***is is all still stock.
    As I dug up an old thread I hope the OP got his fenders sorted out already!
  16. Compton
    Compton
    from Grimesland
    Post error!!! Sorry
  17. oj
    oj
    Check your craigs list for services. I hired a guy from there to do a OT car, he came to the shop with equipment and rolled the lips with a gizmo that bolted onto the drum/hub, did the 4 corners and charged $150. He knew what he was doing and did a good job.
