Romancing The Stone***The Diamond Deuce** Part II
Discussion in 'The Hokey Ass Message Board' started by Jeff Norwell, Sep 14, 2007.
  1. Django
    Django
    from Chicago
    That is looking killer!
    WHY would a guy with a complete '32 sell off the body? He must have a 3 window or roadster, eh?
  2. Jeff Norwell
    Jeff Norwell
    MODERATOR
    UPDATE---
    After a long hard look and what I needed to do next....there were some errors that needed correcting.
    My sched is such I have little (zero!) time to get this thing rolling before the round up.I hauled the whole thing over to my pal BLOWN32 and let have at her.
    The Candyman has the right stuff....impeccable work and talent.
    (Anytime Neil...jump in)
    The box-
    had to be blown apart.... rust and rot repair
    ...and was wacked out of proportion.
    Here are some pics.....
    old box....
  3. Jeff Norwell
    Jeff Norwell
    MODERATOR
    These areas needed to be solved and fixed.
    also...the rolled inner pan for the gas tank was just not working.....it would of trapped moisture and held other nasties....
  4. Jeff Norwell
    Jeff Norwell
    MODERATOR
    More bolts than Frankenstiens monster... uuuggh.....
  5. Jeff Norwell
    Jeff Norwell
    MODERATOR
  6. Jeff Norwell
    Jeff Norwell
    MODERATOR
    more rot under the stake pockets...
  7. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Repaired.....
    All 4 corners....needed much help.
  8. Jeff Norwell
    Jeff Norwell
    MODERATOR
    These were not good...I prefer a clean **** weld.....
    The Candyman came thru......
    These were then in turn shaped and cut to allow proper suspension travel and ease of brake adjustment(bleeding)
  9. Jeff Norwell
    Jeff Norwell
    MODERATOR
    The box was out of square about and inch and a half!...the inner bridge work was bad.
    Neil squared it perfect and all lines add up.
    the tailgate fits like a glove.....(both sides)
    ..I KNEW I didi not measure that rear wrong.....lots of clearence now....perfect.
  10. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Everthing is squared and sits right.....now onto the gas tank(s)
  11. ****, would one would almost think youse were good at this kinda thing :D
  12. Roothawg
    Roothawg
    Looking good Jeff.
  13. Jeff Norwell
    Jeff Norwell
    MODERATOR
    As I mentioned..the cradle that held the moon style tank had to go....kinda didn't make sense....and it would have jolted and bumped around causing wear on the tank itself.(not to mention a moisture trap)
    so..out it went and a metal girdle was formed
    Metal tips will hold the tank in place and the retaining straps will lock her down.
  14. Jeff Norwell
    Jeff Norwell
    MODERATOR
    This all Blown32's doing fellas....a real talented mother.....
  15. Jeff Norwell
    Jeff Norwell
    MODERATOR
    here are some more shots....we will have the metal straps holding it and I have a tack maker(horse tack maker)making some really nice belts with cool tie-down hardware....should look slick.
  16. Jeff Norwell
    Jeff Norwell
    MODERATOR
    As I mentioned..... there is gonna be 2 gas tanks.....this MAS tank will serve as a "reserve".... the main tank will be behind the rear wheels,inside the bed.
    Were still figuring out the delivery system....
    All in all..I should get around 22-25 gallons.
    Hemis are thirsty.
  17. Jeff Norwell
    Jeff Norwell
    MODERATOR
    The drivers door got fixed as well....the bottom was not done and was rotten.
  18. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I was not happy with the heavy look of a 32 box....needed a roll...here and there.....
  19. Jeff Norwell
    Jeff Norwell
    MODERATOR
    The lower section between the rear wheel and cab(of the box) looked like a dogs **** hanging down.....it had to be corrected....
    Ahhh.....mucho better!
  20. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Moving to the rear lower section of the bed...Candyman made sweet success!
  21. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Remember how I said I wanted to use the original nerf instead of the push bar?
    it turned out great....and I really wanted the rear exhaust to exit thru the pan.
    instead of frenching.....Neil took the opposite route......
  22. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I was looking for rings(for the exhaust... the Candyman has some Ole ChrisCraft boat tips.....gimme,gimme,gimme.....I had to have them!
  23. Jeff Norwell
    Jeff Norwell
    MODERATOR
    She just has to have a nice ***......
  24. Jeff Norwell
    Jeff Norwell
    MODERATOR
    I keep ya posted on more progress.....
    thanks fellas.
  25. eaglebeak
    eaglebeak
    Jeff;
    I knew Jerry Watson when I lived in Hamilton. I will PM you a couple of names that you may like to get in touch with to find out more information.
    DJ out on Vancouver Island.
  26. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Dude!.....that would be awesome!!..there is still alot of grey area on the history of this car.
    very cool!
  27. poncho
    poncho
    Jeff,,when i seen the article you posted on page i of this thread i thought of this local truck,,from what i remember it to has some history being built in the 50's and having spent time in the shows...i took this pic a bunch years ago and havent seen it around since,and i cant remember what engine it has or any other details..,i figured you would enjoy it!!!
  28. Amazing design and metal work! The truck is truly a reflection of your illustration work! Can't wait to see the finished product!
  29. breeder
    breeder
    you should give up that silly art dream, and build hotrods jeffro!;)
    lookin killer man!
  30. Burny
    Burny
    ****, man, you are putting together one bad*** truck!..I dig the *** end -the nerf bar, the exhaust tips and rolled pan- looks great!...I'll be checkin' in often...keep postin' progress!
