rookie wiring question
Discussion in 'The Hokey Ass Message Board' started by raidmagic, Mar 2, 2011.
  1. raidmagic
    raidmagic
    For the main power wire from the alt. that goes to battery can I put that on the main lug on the starter rather than run it all the way back to the battery. Sorry for the easy question, I didn't have any luck searching for it as I didn't know what to search for. Thanks
  2. Yea that will work just fine.
  3. Da Tinman
    Da Tinman
    it really depends on the motor, gm stuff yeah it will work, but dont try it on a ford.
  4. raidmagic
    raidmagic
    Yep it's GM, seemed in my head it would work but I wanted to check, thanks for the help.
  5. tb33anda3rd
    tb33anda3rd
    it's better not to attach it to the battery post, it would be at risk to corrode. attach it at the other end of the battery cable.
  6. Atwater Mike
    Atwater Mike
    ????? What does this mean? Fords have solenoids...Let's be fair! LOL
  7. Da Tinman
    Da Tinman
    yeah but if you run the battery cable to the starter on a ford the starter wont ever shut off, just sayin lol!
  8. toolman1967
    toolman1967
    I did it that way on the truck. The battery is in the back of the bed and it seemed that it was safer to use that large starter cable to run that leg than using yet another wire. Been running that way for 3 years now with no issues.
  9. aaggie
    aaggie
    My battery is in the trunk so I ran the 10 guage wire from the alternator to the post on the solenoid where the battery cable connects. Another 10 guage wire goes from the solenoid into the car and connects to the power into the fuse box. It works Ok and keeps things neat.
