Rostisserie Question
Discussion in 'The Hokey Ass Message Board' started by Recon, Oct 10, 2010.
  1. Recon
    Recon
    from Smyrna Tn
    OK, so a friend of mine calls tonight and asks my opinion on what the best rotisserie is. To be honest I've never had the privilege of using one, and the couple of people I know who have made theirs.
    So any suggestions? He's gonna use it for 1 car and prob never use it again.
  2. KrisKustomPaint
    KrisKustomPaint
    you could build your own out of two engine stands. If your only gonna use it once i don't think i would fork out the cash for a pre-made one. Make sure you provide for some way to adjust the mounting "height" to get the center of gravity close to the pivot point.
  3. Slag Kustom
    Slag Kustom
    have him buy the best one he can afford. the money he can sell it for when he is done. any loss he takes when selling will be less then the money he would spend on buying metal to make one.
  4. racinman
    racinman
    Roto-Body-Frame this is the most well designed and universal for anything Bodys or frames or about what ever you can bolt to it... and it is safe!
    racinman Rick
  5. Buzznut
    Buzznut
    I built mine and it us an undertaking AND it's not cheap, not to mention that you need to be a fairly decent welder to pull it off. I say buy a good one and resell it like already said...
  6. 59 brook
    59 brook
    Accesyble technologies around $850 complete held my 59 ford wagon made life much easier folds up when your done i could probably sell it and recoup 3/4 of what i paid
  7. flatmotor40
    flatmotor40
    from georgia
    bought mine from Summit picked it up at the store in Ga no shipping
  8. Accessible Systems?
    http://www.accessiblesystems.com/
  9. prost34
    prost34
    I bought a cheap one and modified it to my liking,used spindles all the way around and mounted rims and tires on it so i can roll it around easy on my crush stone yard,the front turns,rotors in the rear have e brake to hold it still,hydro rams from harbor frieght to raise or lower,not very pretty but,i will never work on another car without it!!!:D
  10. Kingman
    Kingman
    See if you can find another guy or two who will be needing one dowm the line.Use it than p*** it on split the cost.When you sell it your loss will be much less.
  11. dabirdguy
    dabirdguy
    I built my own:
    http://glennsplace.com/on_the_rotiss.htm
    http://glennsplace.com/rotisserie.htm
    The only "tricks" are to get the pivot point in the center of the WEIGHT of the car and to tie the ends together with stout enough material so that they don't seperate.
    My first try was lucky. I could spin the car 360 degrees with one hand.
    It's for sale if you want to come to st. Louis to get it.
    I uses 2x2 angle iron to tie them together.
  12. 59 brook
    59 brook
  13. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I would just roll the car on its side with tires and if you have to stiffen the body ,Wood
  14. hrm2k
    hrm2k
  15. J&JHotrods
    J&JHotrods
    Ours is a whirly jig out of tennessee. A bit pricier than some other rotissiries, but we are very happy with it. I can move the body around the shop by myself safely. Sorry for the bad cell phone pic.
  16. FrozenMerc
    FrozenMerc
    I built my own. I have a '62 Mercury Montery Wagon Body on it. I have a little better than $500 in materials (jacks, casters, and steel) into it. I designed it on CAD, and I do have pdf's of the plans that I made if you are interested, PM me.
  17. 49ratfink
    49ratfink
    I built mine from scrounged metal. I did have to buy a couple pieces though... I think I was into it for about $60. worked quite well.
  18. Mike51Merc
    Mike51Merc
    With all the advice to buy one and then sell it, where are the used ones for sale?
  19. budd
    budd
    if you were to build your own then use steel that could be reused down the road, 2x2 tubing is nice, 2x3 tubing could become a frame one day.
  20. KrisKustomPaint
    KrisKustomPaint
    it always surprise me how many people would have you buy something that is so simple to make.
  21. 59 brook
    59 brook
    yes it is simple to make but it seems most guys spend almost as much plus a day or two of labor to save a hundred buxs or so . if time is limited it could be well spent on something more rewarding
  22. JOECOOL
    JOECOOL
    [img=http://img843.imageshack.us/img843/1725/dcp0448.th.jpg]
    [img=http://img843.imageshack.us/img843/3605/dcp0447.th.jpg]
    [img=http://img843.imageshack.us/img843/2434/dcp0446.th.jpg]
    [img=http://img145.imageshack.us/img145/8369/dcp0444.th.jpg]
    I think you are making it too hard, Mine is made with round tube, same as roll bar stuff,and bent in a c shape with a crossbar. I 45 degreed the ends for a short space and then went 45 again for a 90. Most cars I can turn myself, when I don't need it it takes up hardly any space . My pics are **** but hopefully you can see what I did. A big pivoting 600 lb creation was what I did not want . Best of luck. Oh ,cost should be less than $100.
  23. Brad54
    Brad54
    from Atl Ga
    I investigated a lot of them for a story I did.
    I ended up going with one from Summit... had a lot of nice features, a good design, and it was very affordable.
    If you're gonna lay down a grand, do some searching on the internet and look at the different features each has, decide which ones you would actually use versus which ones are cool but you won't use, and look at how it stores when you take it apart and are done using it.
    A lot of guys say "Build your own," and that's certainly an option too... but by the time you get done buying the material (plus driving to pick it up or paying to have it delivered), buying the consumables (chop saw blades, welding wire and gas), hardware, quality casters, and hydraulic rams to raise or lower it, plus the time to draw out the design, you're into it for nearly what someone else sells it for.
    Rather than have one more project waiting for me to complete, I went the commercially-available route.
    Also, let's be honest--we've ALL seen a lot of rotisseries that guys have built on their own because "It's simple, and I didn't want to pay all that money," and they not only look like Fido's ***, they don't perform worth a ****.
    You're going to be rotating your car body on it... I feel better using R&D someone ELSE spent 10 years worth of trial and error to ensure the car isn't going to high-center and flip over on its own and smash the roof into the concrete, twist or flex the body, and have it set up so one guy can rotate it over safely.
    -Brad
  24. dabirdguy
    dabirdguy
    I spent more for the wheels ($120) than I did for the steel in mine.
    Hunt the junkpiles!
  25. Bert Kollar
    Bert Kollar
    I used and engine stand for the front, a couple simple brackets, and suspended the rear from above (anything substantial will do. Have done two frames so far and getting ready to start another project. just be creative
  26. Brad54
    Brad54
    from Atl Ga
    At that point, if you just want to get the body off the frame, some saw horses made out of 2x6 planks bolted together work nicely. I did that with my '56 Chevy back in '87.
    If the point is to flip the body over, then an engine stand and rope from the rafters won't do.
    -Brad
  27. MP&C
    MP&C
  28. Big_John
    Big_John
    from Upstate NY
    Exactly the reasons why I bought mine rather then build one. I bought a US Car Tool without the jack or casters. I bought two jacks at Harbor Freight and some nice casters from Grizzly Industrial, saving a bunch of cash over the ones offered by US Tool.
    The other issue is resale. I'm not going to do another full on resto and will most likely sell my rotisserie when I'm done. I can easily sell it and recoup 1/2 to 2/3 of what I spent. Selling a home built rotisserie, no matter how well they are designed and built can be tough.
  29. BigRy
    BigRy
    from colorado
    Well I just finished mine. Bought the plans off the net, 600.00 in steel,100.00 for nuts and bolts. My time, add all that up and you can by one for a 1000.00. I do see them for sale every once and a while for 800.00 was the last one. It really is your choice. I will be using mine a lot and have a couple of freinds that will use it also. So a great investment for me and I bought local, so helping small local buisnesses stay afloat in these times.
  30. troylee
    troylee
    I have 2. Built the first and bought the 2nd. Greg Smith equipment. By the way my uncle has the summit one and they look the same. The wheels **** on my store bought one but has workout good other than that. O and if you build one put 3 wheels on each twirler stand. Will thank your self later.
