I have a Rotary 2 post lift model SPOA 7. I need to replace the slider blocks in 1 side Anyone have any experience doing this project?
SVI in Delano, Il probably stocks the parts you need. They are an aftermarket supplier of lift and hydraulic components for lifts and other garage equipment.
I had the Rotary guy here to look at it a month ago. He poured a 1/2 pint of additive to the tank and said that the noise would go away....didn't louder now! I can see that the slider block is worn away on 1 side I need to find out how much work to replace blocks
They replaced ours at the shop a couple years ago. They dis***embled it and laid the posts down on the floor to get the cariage out of the top of the columns.
Just did this on mine. Unhook the cables, hydraulic hoses and removed the arm's. My son and a friend laid it down. Unbolt the top cap and unhook the chain, slide the carrier out. Mine is the type without the top crossover with the stop. Please ignore the late model OT POS.
