Rotating pics
Discussion in 'Questions & Suggestions' started by bjinx, May 14, 2024.
  1. bjinx
    bjinx
    When I upload a pic it is rotated. I double clicked on the pic and rotated it back, but cant save. How can I rotate the pic?
    Thks
    Here is the pic.
  2. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Try rotating the pic then renaming it with just a word, no dashes or spaces and hit save to see if that works.
    Crosley likes this.
  3. bjinx
    bjinx
    Thks
    I will try that
  4. bjinx
    bjinx
  5. bjinx
    bjinx
    I figured it out.
    Thks CCC
    lothiandon1940 likes this.
  6. jnaki
    jnaki
    Hello,
    There are a couple of ways to easily rotate your photo you pasted on a Microsoft Word Program page. See below. Once you paste it, click on it and the symbols and dots show up. This is also a good time to temporarily resize the photo to fit your needs. Use the bubbles on the corners in or out to adjust. The larger arrow circle icon is one that will rotate your photo is this is the correct size of photo you want.
    If you click on the rotating arrow, another black circle arrow is the key to moving your photo around in a circle to get what angle you want. The photos are only up to 90 degrees. If you want more degrees, keep rotating the dark circular arrow.
    If by chance you have already saved your photo to your computer files, then now, it is easier to rotate the whole thing.
    Right click on your mouse and the black pop up gives you a choice as to what you want to do with the photo. Obviously, it is saved to your files. If not, now is the time to “save image as…”
    Then the photo in question gets saved to your own files as a JPEG photo format.
    Now, use that circular arrow to rotate your photo around to any size or view.
    180 degree view was two clicks away.
    Jnaki
    Now you can save it to your own computer files and you will have the original photo angle and your new 180 degree view or what ever angle you want.
    All you need to do is right click the center of the photo, copy, and paste on any post. Or, you can paste it on a Microsoft Word page, to make your final size photo, so it does not go full frame and get blurry on the HAMB page.
    If you paste it on a Microsoft word page first, you can adjust it to any size to fit your typed story.
  7. bjinx
    bjinx
    Thks for the info.
    Much appreciated.
    jnaki likes this.
