Technical Round back spindle question
Discussion in 'The Hokey Ass Message Board' started by pprather, Aug 14, 2023.
  1. I have P&J round back spindles.
    I'm working on hiding the disc brake rotor. The space available behind the rotor is insufficient.
    Is there a safe way to space the wheel hub out slightly toward the end of the spindle?
    Thanks.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Wouldn’t the amount of spindle threads that stick out beyond the castle nut tell you so long as seal still can ride well at the root of the spindle?
  3. 05snopro440
    05snopro440
    You would also need to space out your bearings, wouldn't you? Seems like it gets complicated fast.
    Space out the inner bearing, sure. Then the outer bearing doesn't sit against the taper on the spindle. Smaller inner bearing, then? That equals higher bearing speeds. Sounds like a can o'worms to me.
    Johnny Gee likes this.
  4. 05snopro440
    05snopro440
    Hilltop Cast makes some backing plates for this purpose. Maybe their design will help you figure out what you need to do?
    https://www.hilltopcast.com/product-page/heavy-finned-backing-plates
    https://www.hilltopcast.com/product-page/disc-brake-backing-plate
    2Blue2 and pprather like this.
  5. I think I will try to find someone to mill a little off the caliper bracket. I just need to get a measurement as to how much.
    Thanks guys.
    05snopro440 likes this.
