roundbody Falcon rolled pans
Discussion in 'The Hokey Ass Message Board' started by 62rebel, Apr 23, 2009.
  1. 62rebel
    62rebel
    not going to dig through 800 posts in the two Falcon threads looking for this; show me what you've done with roundbody (60-63, but especially 62) falcons and rolled front and rear pans. want to ditch the bumpers on my '62 tudor when i radius the rear wheel wells.
  2. 62rebel
    62rebel
  3. grits
    grits
  4. bellydraggin63
    bellydraggin63
    the rear is easy, the front is a *****. the mounts for the strut rods are in the way and needed to be moved if you do a full front roll pan. ill try to dig up the pics of the one i did......
  5. 62rebel
    62rebel
    how about radiusing the rear wheel wells using cuts from front fenders? any tips tricks tripups? seen a few finished pics but would like to see some in-progress pics to see HOW it's done.
  6. Mercury Kid
    Mercury Kid
    '60-'61 have a factory rolled pan in the front. Just take off the bumper and fill in the holes. You'll have to roll some sheetmetal around a pole or something for the '62-'63.
  7. Powerband
    Powerband
    Intereated in the RADIUSING wheel wells on the early bird....
    Workin' on a '61 Comet which shares most of the tin with Falcon.
    Open to any useful suggestions for accomplishing. The wheel wells were perforated and I cut and cleaned up to problem areas.
    > Simple problem I'm working on is Falcon/Comet side reliefs in the Radius...
    > What to do where radius well cuts across concave relief...
    I put adverts' out for fender lips but Comet's are different and not easily available
    Used the front fender for radius template but doesn't really work out simply, on rear panel.
    HAve Fun...
  8. chromedaddyo
    chromedaddyo
    from Ohio
    Look at 65 mustang fronts
