Technical RPM constant in drive
Discussion in 'The Hokey Ass Message Board' started by shortbusted, Sep 13, 2014.
  1. shortbusted
    shortbusted
    from texas
    I'm not sure what to make of this one: The engine idles and builds RPM's as it should in park and neutral. I shift into drive, floor the gas pedal, and the RPM's change very little.
    Car is a '56 Ford with a 292 and automatic. It is all stock. Any suggestions are appreciated.
  2. unkledaddy
    unkledaddy
    When is the last time you changed your fuel filter?
  3. 49ratfink
    49ratfink
    when you post a question about something you should try to post your question so the answers will not be more questions.
    all I can say is release the parking brake.
  4. shortbusted
    shortbusted
    from texas
    Fuel filter was replaced last week. Engine also has new spark plugs, points, condenser, and adjusted valves.
  5. shortbusted
    shortbusted
    from texas
    I don't mind answering questions if it gets me headed in the right direction. Sorry to have wasted 2 seconds of your Saturday with my original post.
  6. If you floor the pedal and Rpms don't change nor does the engine stall I'd be looking first for a linkage issue to see that the throttle blades in the carb are opening. Next I'd be looking for a really bad air restriction some place.
  7. shortbusted
    shortbusted
    from texas
    Linkage looks to operating properly. The engine revs fine in park and neutral. RPM's just don't seem to build when in drive..
  8. Blue One
    Blue One
    from Alberta
    o_O So lets get this straight, will the car move under it's own power in drive or not.
    Your question is confusing as hell, no wonder you get more questions.
    49ratfink likes this.
  9. shortbusted
    shortbusted
    from texas
    The car will move under its own power, but tops out around 30 mph.
  10. Did you look down the carb throat and see the throttle blades move.
    If one were to fully open the throttle on any engine running at 700 Rpms it will either accelerate or stall providing it has free air to grab. Is the air cleaner plugged?
  11. BLAKE
    BLAKE
    Is the vacuum advance on the distributor working?
  12. vintagetinman
    vintagetinman
    if your car was newer i would say it has a plugged catalytic converter . since your car doesn't have a cat i bet you have a rodent nest in you exhaust
  13. Fabber McGee
    Fabber McGee
    I fought a 5 year old El Camino for a couple days one time that acted like that. Finally tracked it down to a muffler baffle that had rusted loose and blocked the outlet of the muffler. Unhook your exhaust and try it then. Might be as simple as a mashed pipe from banging a speed bump.
  14. Did this just happen or did you get the car in this condition? Are the brakes dragging? Can you push the car easily?
  15. aaggie
    aaggie
    Could you have a broken motor mount that lets the engine twist and jam the linkage?
  16. TANNERGANG
    TANNERGANG
    from alabama
    I'd also check and make sure the exhaust wasn't stopped up...years ago when I first started racing I drove for one of the so called big engine and parts owners around...we broke a stock exhaust manifold one night...another racer went home and got us one...we put it on and went out..the car wouldn't run for nothing...it was rich and smutting the plugs on one side...the driver side was perfect...I left the engine to the smart guys cause it was their car and auto parts...their mechanic chased it 3 weeks and the 3rd night, for some dumb reason while leaning over the fender looking at the car in disgust...I reached down and grabbed the exhaust damper at the collector...it was froze up solid and only open about 1/2 inch when we pulled it off.........one of those simple things we never thought to look at...mechanic just knew we had messed something up in that head.......go figure....dumb blind luck
  17. Torana68
    Torana68
    from Australia
    failed torque converter?
  18. txturbo
    txturbo
    usually when a torque converter seizes up it acts like a manual transmission in high gear with the clutch engaged all the time. It will die when you drop it in gear and if you can keep it running it will act like it has no power. Then when you come to a stop it will kill the motor.
