rubber liner over wheel spokes on inside of rim ?
Discussion in 'The Hokey Ass Message Board' started by dirtbag13, Aug 16, 2010.
  1. dirtbag13
    dirtbag13
    have some aftermarket wires i had sandblasted and am wanting to powdercoat ! i see after i got them back there appears to be some sort of rubber liner that almost looks like a rubber band on the inside of the rim , i ***ume its put on there to seel off the spoke ******s and prevent air leaks ? i don't think it would stand a chance in the bake oven though , my question is does anyone know where i could have this reapplied after powdercoating them ? i don't really want to have to run tubes ! thanks for any info ! they are early mclean wheels i believe !
  2. Model A Vette
    Model A Vette
    Just a suggestion:
    How about the rubber dip used for the handles of tools. It could be brushed on.
  3. Weasel
    Weasel
    I think there's a product called Liquid Electrical Tape - it's sold at hardware stores - or call a wire wheel manufacturer - Jimmy at Rally America in Fresno should be able to tell you - he's here on the HAMB under the name Wheelkid.
  4. aaggie
    aaggie
    Rim bands like you describe have been used on spoke wheels since early bicycle times. It is used to keep the ends of the spokes from chafing through the tubes. I can't think of any reliable way to run spoke wheels without inner tubes. Several wraps of good old Duct tape will probably work OK, it does on my bikes and motorcycle wheels.
  5. StanDaManTX
    StanDaManTX
    from The South
    Go to HOME DEPOT, they sell it in spray cans too.
  6. Big Nick
    Big Nick
    just hit a motorcycle shop and pick up some rim straps in the size you need. Or you can probably use the liquid electric tape as said earlier or some sort of silicone.
  7. pan-dragger
    pan-dragger
    I've used windshield urethane to re-seal wire wheels after powder coating them. It works fine.
  8. dirtbag13
    dirtbag13
    i like that idea best so far , just brush it on ? try to apply it even
  9. zman
    zman
    from Garner, NC
    Actually there are quite a few wire rims that are tubeless and reliable. The ones I ran on my Buick are from a Jaguar and tubeless. Daytons are tubeless. Lots of spoke M/C rims are tubeless. Not an issue. But to remove it from a tubeless wire rim I've used silicone. But then I see an issue with powder coating the rims as one piece rather than the individual parts.
  10. I have a set of older wires I run tubes I have been running with the inner liner of course, never had a issue,,,,and I have always used baby powder,to help keep the rubber from chaffing and sticking.
  11. dirtbag13
    dirtbag13
    just called ralleye america and spoke with jimmy aka wheelkid here on the hamb ! he curtiously answered my questions and told me how to re apply the silicon liner ! i will be doing all future business with them and would highly recomend them !
  12. Automotive Stud
    Automotive Stud
    I'd use the rubber bands like a motorcycle. A lot easier to work with later if you need to work on the wheel than something glued to the wheel.
  13. zman
    zman
    from Garner, NC
    Funny thing about those, they don't seal the wheel. If you look he wants to still be able to run tubeless. :rolleyes:
  14. dirtbag13
    dirtbag13
    not planning on running tubes so have to seal the spoke ******s w silicone ! not a big deal peeled the old stuff out w a little elbow grease so not too woried about having to do it again !
