rubber on paint from the drags, need help....
Discussion in 'The Hokey Ass Message Board' started by 1929rats, May 30, 2011.
  1. 1929rats
    1929rats
    This weekend I raced one of the cars....
    apparentlly lots of guys were running radials...
    I have all sorts of rubber on my quarters from the burn out box and am having a bitch of time getting it off....Ive heard in the past to use a petroleum based solvent (like a bug and tar remover), but, that isnt working....
    Does anyone have any ideas? Thought of using acetone, but, decided this evaporates too quickly and is too abrasive for a single stage paint.
    thanks,
    pete
  2. propwash
    propwash
    from Las Vegas
    shake up a bottle of Coca-Cola® and spray it on the detritus. Let it sit a little while, and then it should come off.
    dj
  3. Motornoggin1
    Motornoggin1
    I've used WD-40 with success, as well as citrus oil.
  4. Deuces
    Deuces
    Acetone will eat up your paint job... Don't do it!!!
  5. 61falcon
    61falcon
    i let the car sit in the sun, the rubber dries out and washes right off.
  6. derpr
    derpr
    i'd say WD-40
  7. flamedabone
    flamedabone
    Rubber on your 1/4s is a sign of manlyness and the chicks sure seem to dig it. I say leave it.
    -Abone.
    PS. What did your car run?
  8. gasser300
    gasser300
    from Ft Worth
    Im with Abone.
    and what DID it run?
  9. Badge of honor! But next time smear a wee bit of vasoline on your .lower quarter before the box. Try a crepe wheel , the kind for removing stickers, in your drill. Stay away from hot solvents!!!
  10. gasser300
    gasser300
    from Ft Worth
    OR get you some of that blue masking tape and tape em off.
  11. I use to spray my lower quarters with Pam, before I hit the burn out box. Worked great....
  12. badshifter
    badshifter
    Like they said WD 40, or KENT Acrysol, mineral spirits, most any oil based slow solvent. .
  13. gasser300
    gasser300
    from Ft Worth
    Or do like dirt trackers sometimes do and put some tranny fluid and diesel fuel in a spray bottle and spray em down prior to take off.
  14. stainlesssteelrat
    stainlesssteelrat
    from ms
    why would you want it off? does it have to look THAT pretty on a trailer?
    personaly i'd rathere have people know that i USE the car for something other than
    a paper weight.
  15. boogeracng
    boogeracng
    from Eureka,MO
    WD-40 or Prep Sol....the stuff used before painting.
  16. HealeyRick
    HealeyRick
    from Mass.
    Sounds a little kinky :eek:
  17. hahahahahahahha
  18. Toner283
    Toner283
    Try gasoline on a rag, it has always worked for me.
    And to 345 DeSoto with the Pam tip, I agree. vaseline smeared on the lower quarters works as well. The only catch is that you have to add the Pam or vaseline to the quarters BEFORE you go out & spend the day playing.
  19. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I'd just leave it...it really cant be bugging you that much, right?
  20. TERPU
    TERPU
    Damn Straight!
    Tim
  21. 1929rats
    1929rats
    Car did not run well at all...very hot, had carb problems, then could not hook up for shit.... best was a mid 14. I really hate writing that, but , it is what it is....just got home from work and gonna try the wd-40 thing on one quarter and coke on the other...will let you know....
  22. Thumper
    Thumper
    LMAO........I sprayed a chick named Pam rear quarters once...:eek:
  23. I use Eagle One wheel cleaner, just make sure it is for painted wheels. Works great for removing bugs too...
  24. The Shocker
    The Shocker
    Leave it ,it looks pretty sexy to me .I wash my Drag car occasionally but i got to great lengths not to disturb the melted tire rubber on the lower 1/4's and edges of the rear bumper :) ...
  25. rancid737
    rancid737
    Try 3M adhesive remover.....usually works for me.
  26. Kustom Kid 53
    Kustom Kid 53
    Use masking tape on the 1/4 before you burn out then just pull it off when your done.
  27. HOT ROD BILL
    HOT ROD BILL
    People pay good money to get rubberized coating on lower quarters, prevents rock chips! Mine ain't got no quarters.
  28. LeadSledMerc
    LeadSledMerc
    MID 14...WTF Pete?:eek:
    Stop blamin the carb and the heat and the not hookin up....you must have been sleepin at the light...you should have lied!! :D
    How was up there any ways?
    I was hopin to make it, maybe next time.
  29. 1929rats
    1929rats
    I should have lied...yes indeed....thats embarassing to write, and my reaction time was even more bogus (.3, .4 and so on). my first go of it for the year...
    well, in the past, Ive always at least put wax on the quarters or ive put on the blue tape, but this time, my plans were to go to the drags with my woman and just park my car in the show...then when I got there, I was like, what the f**K, Im at the drags and NOT going to race????!!!!
    anyway, I raced....
    had loads of compound and other guys rubber on the car. The WD-40 did the trick...worked great....way better than the bug and tar cleaner. The coke did not work for me....
  30. indyjps
    indyjps
    Try the gooey, snot hand cleaner. used this in the past and it worked well. I stilluse it to remove bugs / tar during wash and wax time.
    lay a heavy coat of wax on your quarters before hitting the track, I used good old paste turtle wax cause it was cheap but you have to look at the white haze, you could try the newer turtle wax that supposedly doesnt haze black exterior trim. I have a few friends that swear by it for late model cars but i cant bring myself to use it.
