Technical Ruff Running flathead
Discussion in 'The Hokey Ass Message Board' started by Gary Indrebo, Nov 22, 2025.
  1. Gary Indrebo
    Gary Indrebo
    I have a 1940 Ford Deluxe with a new rebuilt 8ba with a Stromburg 97 Carb and Stromburg Distributor. About a month ago it started runing ruff at high rpms, then it started to run ruff all the time. I checked the distributor nothing obvious, I pulled the plugs they were black so I ***umed it was to rich I rebuilt the carb did not help put on a new carb did not help. Any suggestions would be appreciated.
  2. Tim
    Tim
    from KCMO
    Fuel filter
    Mr48chev likes this.
  3. Mr48chev
    "Running rough" covers a lot of territory.
    First thing is general maintenance items such as the fuel filter as Tim mentioned. Simply meaning, did stuff in the tank clog up the filter when you got the car running and driving. That is common on old rides that have sat for a long time and are getting driven now.
    Check the points /dwell if you have a dwell meter.
    Check the vacuum advance. That's another item that fails after sitting for a long time. Get it working back and forth and the diaphragam gives out.
    Flathead Dave likes this.
  4. alchemy
    alchemy
    Real Stromberg carbs or fake ones from Speedway or Vintage Speed?
    big duece and NoSurf like this.
  5. tubman
    tubman
  6. jimmy six
    jimmy six
    Check compression first.
  7. Gary Indrebo
    Gary Indrebo
    Real Stromberg
  8. big duece
    big duece
    from kansas
    I would be curious about trying a regular points distributor with fresh plugs...
  9. jaracer
    jaracer
    Like Jimmy six said, check your compression. That will keep you from just throwing parts at it.
  10. ronnieroadster
    ronnieroadster
    Sometimes a bad condenser can be the problem as well.
  11. CSPIDY
    CSPIDY
    Did you clean and test the plugs?
