Event Coverage Run What Ya Brung Nostalgia Drags- Reynolds, GA Nov 8,2014
Discussion in 'The Hokey Ass Message Board' started by dirty old man, May 30, 2014.
  1. GAOldsman
    GAOldsman
    from Perry, GA
    Circled is where we congregate
    The 1 represents the tech, racing fuel, timing shack area
    The 2 represents the start.
  2. Redsled
    Redsled
    • I did get confirmation from the shirt maker. The shirts will be 15.00 for S-XL, 17.00 for **L & **X L. The color was discussed and we think the gold on black and Black or Blue on the gray ash. I would like to order only shirts that are pre sold. I have gotten stuck with several each year, would not be a problem if they were large or 3xl as I can use them. Let me know what you guys think and want.to do. also we have to have a minimum of 24 to have them made.
    • You can email me at jimmy@46redsled.com. I do have a PayPal if you all are interested?
    GAOldsman likes this.
  3. dirty old man
    dirty old man
    So there it is Sports Fans T shirt info on contact and prices. Remember IF YOU DON'T PRE ORDER AND PRE PAY, YOU DON"T GET A T SHIRT.
    Also bring charcoal for that big old grill, and if you can find a little room in your truck for it, then throw in a few sticks of firewood also.
    It's always a fun event, and looks to be even bigger and better this year. YALL COME, YA HEAR?
  4. Cabbage
    Cabbage
    Looking forward to this. Gnats outta be long gone by then thank goodness
  5. thunderplex
    thunderplex
    I'm interested in a t-shirt but would like to see the design.
  6. GAOldsman
    GAOldsman
    from Perry, GA
    Here is the one from '12, I believe it is the same design but with the date changed.
  7. dirty old man
    dirty old man
    Scot, you are correct, the design will be the same with new date, is what Jimmy told me. I'm going to order 3 as soon as I get the sizes from my son for his and his wife's, and their color choice. They should be on way back from FL trip now.
    Looks like we'[ll have a father/son race between the 2 of us if all goes well. Wonder if there has been one @ RWYB in the past?
    Cabbage, to handle the gnats during their season you gotta learn how to talk like a South GA native. What you've always thought was a lisp in their speech is reall the result of a lifetime of learning to talk while blowing air out of the corners of mouth up across face to blow gnats away!
  8. captmullette
    captmullette
    gotta have a couple
  9. GAOldsman
    GAOldsman
    from Perry, GA
    Hmm I wonder if Jamie and Jimmy has given it a go, but I sure wish I could've run my Dad. I would've been in my '67 Stepside that has a pretty healthy 355 in it versus the '35 Dodge with the 383 stroker :cool:
  10. dirty old man
    dirty old man
    Mounted the slicks on my Amer. Daisy wheels today after going thru a chinese fire drill about tube stem holes in the rims last week. Will do a trial mount on BGII tomorrow. Damn, them ****ers look big!!!!
  11. GAOldsman
    GAOldsman
    from Perry, GA
    Sounds like you are on the short rows now Dave :cool: Did you get your steering/suspension bug worked out?
    [​IMG] Days y'all :cool:
  12. dirty old man
    dirty old man
    Yeah the steering is now pretty much where it needs to be, although at some time in the future I plan to remove tierod again and shorten another quarter inch or so and then use the special taps Josh has to tap them a little deeper. That way if I ever find the need to try actual toe out I will have the adjustment range to do so. Expect my next tires will be radials (please don't tell the trad police on me) and I understand they need less toe in than bias ply. I'm at 1/8" toe in now and don't have any adjustment left towards toe out. When Josh and Tim came down a few weeks ago to pick up the milling machine I had found for Josh, the 3 of us set it up with double lock nuts on the tie rod like I had done already on drag link. Actually Josh and Tim did the work, and I "stupidvised" except for the lathe work..
    Put the slicks on BGII today for a trial fit, and lo and behold! All my measuring and figgering was correct and I have about 1.250" clearance between inner tire sidewall and fenderwell panel, just about right, I think. Also scored a piece of 6" steel pipe to cut for a hoop for my drivesghaft loop. That Crown Vic police special aluminum driveshaft I had shortened for BGII is just too fat for the loop in the kit I got from Mulette. But I can use the "wings" from the kit along with a hoop off the pipe for a fine driveshaft loop installation. Things are looking good!
  13. captmullette
    captmullette
    sounds like your loading up for bear dave....im going to napa to day and get some king pin shims to take the slop out of my axle, then when I get a friend over here to help, im gonna re-measure everything, ill pull the axle this winter and have it checked, packed the wheel bearing yesterday and swapped sides with the tires....trying to get ready for RWYB
  14. BAD A
    BAD A
    I am going to wash mine. Then a couple of days, before the event. I will put my new tires on. Plus I am waiting to see what the weather will be. Then I can choose, which trailer we are going to use.
  15. GAOldsman
    GAOldsman
    from Perry, GA
    Sounds like a plan Dave.
    It seems as if I am going to have to nix the slicks this year. Just can't justify spending that kind of dough for one day out of the year. Still fun fun fun so 13.70's will have to suffice :cool: Hopefully I can cut the reaction time down and work on the 60' times.
  16. captmullette
    captmullette
    scott, talk to me at the rwyb, I need a wider tire on my car, ive got those MT ET streets im gonna sale.....ill make you a good deal.....
  17. GAOldsman
    GAOldsman
    from Perry, GA
    Sounds great Bobby. What size are they again?
  18. captmullette
    captmullette
    p315/60r/ 15 et street radials, at least 90% tread.......
  19. GAOldsman
    GAOldsman
    from Perry, GA
    Aw man, I was afraid of that. That's pretty much the same size as my Hoosiers. I am trying to go smaller in hopes of not being so boggish off of the line. The ones I was looking at were 26" tall. I will check them out if you still have them in Nov though.
  20. captmullette
    captmullette
    saw some 26's and 28's on racing junk .com
  21. GAOldsman
    GAOldsman
    from Perry, GA
    Thanks Bobby, I'll check it out brother :cool:
  22. dirty old man
    dirty old man
    Damn!! I let my attention get on something else for just a day, and this thread is back on page 9. Bump Dammit!!!!
  23. GAOldsman
    GAOldsman
    from Perry, GA
    Found a couple of steelies so slicks may still be in the cards. :confused:
  24. captmullette
    captmullette
    oh yea!!!!
  25. dirty old man
    dirty old man
    Good deal!!!!!!!! Glad you found some wheels, now find some slicks, cause I don't want you using street tires against my slicks for an excuse when I blow the doors off that Dodge!!!!!!!!! LOL!!! Seriously though, glad you were able to score some wheels.
    Started in again today on the driveshaft hoop and was making good progress when my eyegl***es fell apart and I had to quit and go get thm fixed.
    Still gotta get a line-loc on it also.
  26. GAOldsman
    GAOldsman
    from Perry, GA
    Dave according to your 1/8th mile times, I can't hang with the ole BG LOL :D But I'll dang sure give it a go :cool:
  27. dirty old man
    dirty old man
    What's your 1/8 mile time?
  28. GAOldsman
    GAOldsman
    from Perry, GA
    My best has been a paltry 8.68 :eek:
  29. dirty old man
    dirty old man
    You're definitely hurting off the line. Between those tall, heavy tires, tight converter, and rear gear ratio, they're all ganging up on you.
  30. GAOldsman
    GAOldsman
    from Perry, GA
    Yup, you nailed it Dave. Although the 3.73:1 rear gear should be suffice, the tall and heavy tires kill that. Hopefully the shorter, lighter slicks will accomplish two things, loosen up the converter and make the gear a bit steeper. Not sure what that is going to do to my trap speed, but it should help all the way around. Thankfully I do still have that third pedal under the dash. And next year it just may have three pedals again like hot rods ought to have anyways. :cool:
