Run with no carb???
Discussion in 'The Hokey Ass Message Board' started by Blades, Jan 17, 2012.
  1. No he is just over thinking things.
    We used to drain the water from an engine that was going to sit over the winter. No need to change the oil for winterization for sure, and fuel stabilizer does not need to fill the fuel lines there just isn't that much fuel in the lines and it will probably evaporate before spring.
    Never the less what I described will work. Keep it simple.
  2. 1952henry
    1952henry
    And to think fools pay good money for av gas when they could just use the wind once the props were spinning!:confused:
  3. I tried the gas down the intake once and only once. Its amazing how fast the engine will rev up . I only used a bit of gas and it rev'd way higher than a normal engiune should. I will never do this again . And I do rev engines but not like this!! Uncontrolled!!!
  4. Exactly .... and he can drive it into the shop to winterize on the starter.
  5. Truckedup
    Truckedup
    That's ok with me because I excel at failing metal tests that limit bizarre thoughts :D I have actually driven more than one vehicle with not throttle control using the ignition to control engine speed.Broken throttle cable at the carb on an old Triumph cycle.Jam a stick in the carb to hold the slide valve about 1/4 way open,kick start and using the right thumb to fan the kill ****on keeping engine speed reasonable for limp home riding.
    The OP asked about starting his car's engine.Obviously he doesn't need to start the engine to do what he wants to do,but that is the question he asked...........
  6. styleline
    styleline
    from so-hol
    winterize mine sits sins september also,get it out around april the only thing i do every year is take the tension off the valve springs,make sure my gas tank&carb is completly full disconect the battery cables an thats it
  7. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    YES. Just hook up a vacuum cleaner to it and hook up a gravity fed gas line. The vacuum will most likely explode, but its just a little bump in the road.
  8. Truckedup
    Truckedup
    A non feathered prop on a multi engine aircraft with a dead engine can severely over speed the prop and engine resulting in the prop shearing off it's shaft or the engine will sieze and the whole ***embly tears from the mounts. Now you're not confused :D
  9. rsg2506
    rsg2506
    I'd hold off on winterizing in January. It's too cold out there. I'd wait until March when it warms up a little.
  10. BJR
    BJR
    You have a good point. We did it with the carb in place on a boat when we ran out of fuel out on a lake. It got us back to the landing no problem. Didn't think of no air control though. I'm betting you are correct.
  11. metalshapes
    metalshapes
    I worked in a shop where they tried to run a diesel without its throttle controll ( which was weird, but that's how that thing was built )
    It ran at WOT, with no way of shutting it off.
    We stopped it by unscrewing the pressure lines coming off the pump.
    I later heard it got stranded on the side off the road with a broken crank.
    So can you run your engine without a carb?
    Yes.
    Does it accomplish anything?
    No.
    Would it be a lot of work, and could it damage the engine?
    Yep.
    I think you should go for it.
    People have done dumber things for worse reasons....
  12. Don's Hot Rods
    Don's Hot Rods
    from florida
    So what we have learned from this is:
    1) Yes, and engine will fire with gas poured down a bare intake.
    2) Should you do it? No, it will rev too high.
    3) You do not need to start an engine to winterize it.
    4) Traditions Racing has a better avatar than me. :D
    Don
  13. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Some of the other advice was real, too......you just didn't like it.
  14. Metalshapers, I'm sure you know that diesels can " run away " even with throttle controls attatched. Happened to a old Detroit Diesel for our race boat hauler, it didn't end well.
  15. Thanks Don, her sister is in the backround. She " winterizes " the revolvers.............uh wait, I have a call coming in from Ryan.......................just a little reminder we are a family forum, "thanks buddy".
  16. MrChipFooce
    MrChipFooce
    from LOCATION
  17. Blades
    Blades
    from Chicago
    Mods, i think this thread has run its course, please close
  18. You might want to make a block-off plate for the carb flange on the intake manifold. If this thing doesn't have a carb right now ... it might end up sitting a lot longer than you think it will. No sense giving the mice a nice place to live.
    If the antifreeze in still good, I don't really see a reason to change it. If there is no antifreeze in the engine, you better make sure you drain the block of all water and not just the rad.
    I agree with most of the others ... I would NOT try to start it without a carb, there really is no reason to start it. It could work in your favor if you throw a rod through the block though :D ... "gee honey the old 6 just died, can I have a V8?".
  19. czuch
    czuch
    from vail az
    If you had a carb, you could drive it all winter.
    Carb = good.
    Spray bottle = bad.
    Fire = bad.
    Send videos.
    Make sure the camera is onna tripod so we get to see the whole schmeer.
  20. czuch
    czuch
    from vail az
    Nothing said about cant find a carb for your particular build.
    Theres as much snark here as very sound advice. Just Boys and Girls having fun.
    Dont call the teacher just because the girls chased you into the bathroom.
  21. Muttley
    Muttley
    This could make for some awesome comedy, be sure to film it and post a YouTube video.
  22. Mike51Merc
    Mike51Merc
    Do a Youtube search for "runaway diesel". Since there's no ignition to turn off, the only way to kill them is to choke them by blocking the intake.
  23. He really looks like that. Make me jealous, if I had a pair of those I would never have to leave the house.
    Oh you were talking about the pistol weren't you. My bad. :D
  24. Mike51Merc
    Mike51Merc
    You started it! Starting a thread here is alot like starting an engine without a carburetor, it revs like crazy and there's no control over it.
    Honestly, it takes about 5 minutes to install a one barrel carb on a straight six. Why flirt with disaster?
  25. Hnstray
    Hnstray
    from Quincy, IL
    Spoilsport !! :D
    Ray
