Projects Running 49 flathead
Discussion in 'The Hokey Ass Message Board' started by bagel56, Sep 4, 2023.
  1. bagel56
    bagel56
    from So. Cal.
  2. joel
    joel
    Maybe carbs are too rich. Check the distributor, if using the Loadamatic.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    Short video. Really too hard to judge.
    Seems to be taking gas well.
    The valves seem a little too noisy. But that’s only a small impression based on what little can be seen. Exactly what are you suspecting?
  4. bagel56
    bagel56
    from So. Cal.
    Motor missing and a non operating piston.
  5. bagel56
    bagel56
    from So. Cal.
    The motor is new.
  6. Doublepumper
    Doublepumper
    from OR-WA, USA
    Couple wires crossed...?
  7. Petejoe
    Petejoe
    from Zoar, Ohio
    Is this a test? :)
    Need type of distributor please.
    Lots can be attributed to a miss.
    Compression? Plug fouled?
    Plug wire bad and distributor shorts
  8. inthweedz
    inthweedz
    Ok, you say ''The motor is new.''
    It's a bit hard to hear with the straight pipes, but to me it sounds a bit retarded. (I could be wrong)
    Has it had a tune up proir to starting, as in set plug gap, HT leads in the correct order, points / cam dwell and timing set, carb float level, and idle mixture set??
  9. bagel56
    bagel56
    from So. Cal.
    MSD distributor. NASA conducts tests! I'll have to take it back to the builder.
  10. chicken
    chicken
    from Kansas
    This. 15486372....notice 8 and 2 are reversed from later Ford firing order.
  11. bagel56
    bagel56
    from So. Cal.
    I'll have to take it to the builder via shipment.
  12. wheeltramp brian
    wheeltramp brian
    Just wondering who the builder was. And did they dyno test it first?
  13. bagel56
    bagel56
    from So. Cal.
    The builder was Jeff Jones located in Fresno California. I don't believe it was dynoed.
  14. bagel56
    bagel56
    from So. Cal.
  15. bagel56
    bagel56
    from So. Cal.
    I got it running, however, the motor wants to cut out after 3rd gear. So what is happening?
  16. chicken
    chicken
    from Kansas
    Most likely cause is fuel starvation.
  17. bagel56
    bagel56
    from So. Cal.
    20231024_152429.jpg IMG_20231024_165551.jpg IMG_20231024_165547.jpg IMG_20231024_165547.jpg
  18. alchemy
    alchemy
    5 and 7 are rather clean. Are they getting steam cleaned from a little leaking water?
  19. SS327
    SS327
    You painted it purple! No wonder it’s pissed off and not behaving right.
    Fortunateson likes this.
  20. bagel56
    bagel56
    from So. Cal.
    Don't know
