Technical Running a Mag on the street or an Imitation
Discussion in 'Traditional Hot Rods' started by FNG, Sep 14, 2020.
  1. FNG
    FNG
    from New Jersey
    I'll keep this short and sweet
    What are your thoughts about running a magneto on the street, or one of those electronic ignitions look-alike mags, the application is a small block Chevy. Does anyone run a magneto on the street anymore or what about those ones that look like a mag but house electronic ignition.
    Your thoughts are greatly appreciated as always
  2. Roothawg
    Roothawg
    Magnetos are not well suited for the street, but they can be run. Magnetos spark increases as rpms do. Spark at idle is minimal, so cold starting could be an issue. They have to be grounded to kill the engine, so a kill switch would be required. Also, solid core wires are required.
    I think the magneto look alikes would not perform any better. I haven't heard about their reliability yet, but I think they had some issues. It's the only real option out there for the early Cadillac engines, so I have wondered the same. I'll probably end up with a Pertronix conversion.
    Read this. https://www.jalopyjournal.com/forum/threads/joe-hunt-distributor-issue.683577/
  3. slayer
    slayer
    Tried the fake Joe Hunt, just replaced it with a MSD ready to run distributor. The fake mag is a cool idea on theory, but the execution is poor. I haven't run a mag on the street, but would try that before the Joe hunt deal again. There are multiple threads here about the low reliability rate of the fake magneto's.
    Bandit Billy, X38 and loudbang like this.
  4. Mr48chev
    I'd want to say that the main reason for running a mag on the street is that the whole build looks 1oo% race car with a license plate and a distributor and coil would look out of place.
    One has to remember that the majority of race cars that run them now don't have batteries or even a starter and are push start circle burners. They work pretty good on those dirt track sprint cars.
    dirty old man, thintin and loudbang like this.
  5. lippy
    lippy
    from Ks
    I'm sorry I have to disagree about running a magneto on the street. I think the FAA would also. Aircraft have been running magneto's forever. Have a vertex freshened up and rare earth magnets installed. You can get 5-7 amps out of an old vertex with the right mods. That will light dirty dish water. And they are very reliable. Lippy
  6. Mr48chev
    I forgot that one, My thoughts were more on running an old used one on a mild engine just to look the part. I've been around too many guys who stick race car parts on a mild street engine in the past 50 years and then can't get it dialed in to where it drives decent.
  7. lippy
    lippy
    from Ks
    :DYeah too many people just buy an old wore out mag and stick it in the car and are disappointed. You need to send the old drag raced wore out mag off to someone like Spud miller and get it rebuilt. Still cost you the same as a non traditional MSD or whatever. But properly curved and set up , they are very reliable. Independent of the battery it will get you home when the battery goes ****. And you have more firewall clearance. (If it 's a chevy) lol. When you get into the higher amp stuff you'll need an external condenser and coil and a big cap. But for the street you shouldn't need more than a 2 amp mag. So it still looks the same on the outside as far as dimensions. A good vertex will start fine, in all conditions on gas. JMO. Lippy
  8. lippy
    lippy
    from Ks
    Should have kept my mouth shut now all those cheap vertex's I been buying are gonna go up. :D
  9. UNSHINED 2
    UNSHINED 2
    Yeah---Thanks a lot!:D;)
    61cad, 427 sleeper and lothiandon1940 like this.
  10. 51box
    51box
    from MA
    I run a Vertex mag in my coupe around 6k miles now and it works flawlessly. I sent the mag to Pat Mason in PA and had him add mechanical advance and freshen it up. Highly recommend him for fast turn around and price can’t be beat.
    My HD has a magneto also and I’ve never had a problem with it even getting caught in the rain etc.
    Paul, loudbang, Roothawg and 4 others like this.
  11. 61cad
    61cad
    Yep... Mags rule..
    Mechanical advance is the way to go on the street.
    I have a friend /client that put 300k and 40 years on a single vertex mag before needing a freshening up.
    Paul, hotcoupe, loudbang and 4 others like this.
  12. X38
    X38
    Heard a lot bad, never heard anything good.
  13. da34guy
    da34guy
    2020 chopped 34 in da fog.jpg Over 6500 trouble free miles with 1 in this 1, it's a Vertex
  14. 2OLD2FAST
    2OLD2FAST
    from illinois
    Most every small engine ( lawnmower , chainsaw , older outboards ,etc.) Is fired by a magneto ,they are dead nuts reliable , require very few parts , aren't particularly electrically sensitive ,they fire at low (300+-rpm) & require virtually 0 maintenance......sounds like a win ,,win ??
  15. Jmountainjr
    Jmountainjr
    As originally built, the magnets require periodic recharge, the majority did not have and advance, and put out about 1 amp. So as mentioned, an old tired mag is most likely the source of the bad press you hear from guys that did not do enough homework before installing one. Upgrading to rare earth magnets as mentioned by Lippy eliminate the need for periodic recharging and boosts the output to the 1.8 to 2 amp range. Advance plates are available in 7 or 12 degree advance (mag degrees), so you can add in 14 or 24 engine degrees of advance. It's weight controlled, so tend to come in a bit early and not really something you can fine tune, but never been an issue. I sent an old Vertex that was well used but did have a 12 degree plate in it and sent it to Spud Miller for the rare earth magnet upgrade and an overhaul and couldn't be happier with the mag or the service from Spud. For street use you need to know: that you need a stout kill switch; solid core plug wires; run 0.018" to 0.022" spark gap; the mag isn't compatible with any electronics or your radio; you need a buzz box to time it. So it depends on just what you are putting together and your personal tastes if a mag is right for you. I know several guys that went with the fake mag because they could not live without a radio and / or had electronic controls that they wanted to run. They have had some reliability issues with the fake mags.
  16. Stan Back
    Stan Back
    In the early 60s, Mallory had a mag called an Mini-Mag. We had two of them – one street version and one race version for our drag roadster. The street version had a coil and a "magic box" full of electric devices (you can tell I'm real big on electrical parts). They were supposed to help start at slow cranking speeds. I ended up with three of them years later. I took them to Scotty's house where he had an early distributor machine so he could select the right one for me. We opened the boxes and all three had different elements. One of them burned up on his machine. I ended up using a stock points ignition.
    Elcohaulic and FNG like this.
  17. Roothawg
    Roothawg
    FYI, the FAA generally requires 2 mags for redundancy. Wonder why that is? I am not arguing that they are reliable, but they do have some drawbacks. The rare earth magnets are the best thing to do to one. I am getting ready to send mine out in the near future and that is on the list.
    Oh and FYI, even bad mags that won't fire can bring you to your knees....ask me how I know.
    Tman, INVISIBLEKID and loudbang like this.
  18. 61cad
    61cad
    All thing mechanical do and will fail... Really bad things happen when your engine dies a couple thousand feet in the air.
  19. Mike VV
    Mike VV
    from SoCal
    Many older Harley motorcycles use a magneto..! Try kick starting your small Chevy.
    1. Freshen the magnets, as has been said, rare earth magnets. And-or the OXC, separate coil.
    2. New cap and rotor
    3. Solid core plug wires
    4. A heavy gauge ground (shutoff) wire. I used to use a...spark plug wire.
    5. A heavy duty switch for grounding the mag. NOT...as part of the "cars" electrical system.
    Mike
  20. Roothawg
    Roothawg
    I understand. I work for the FAA, as the Quality Control Inspector Manager. It was a tongue in cheek statement.
    loudbang, warbird1 and 61cad like this.
  21. Elcohaulic
    Elcohaulic
    Get a stock points distributor an use it to trigger a CD box... This set up can't be beat..
    I never cared for things that are fake...
    Ned Ludd and loudbang like this.
  22. lippy
    lippy
    from Ks
    Hey Root, if you really want to piss yourself, (Don't know why you would but)... Grab a plug wire on a D John deere when cranking to start. While the impulse is making that clacking noise. :p WOW.
    Tman and loudbang like this.
  23. drtrcrV-8
    drtrcrV-8
    Years ago ('60s-'70s) ran a Vertex on the street with no mag-related issues on several different motors, & would do so again if the vehicle was not subject to the current emissions regulations( meaning that anything HAMB friendly would be in the "clear"!!)
    Elcohaulic and loudbang like this.
  24. Roothawg
    Roothawg
    I was standing at the speed shop spinning my vintage Vertex to prove it wouldn’t fire....welp, it made a fool of me. The guys at the counter were amused though.
  25. dreracecar
    dreracecar
    from so-cal
    There is a relay kit available so that a standard ignition start switch can be used, so the need for a separate mag kill is un-necessary
  26. Marty Strode
    Marty Strode
  27. Harv
    Harv
    from Sydney
    Agree - pretty simple to integrate a magneto into a "normal" keyed ignition switch. Easy to do without a kit. Use the old coil +12V line to drive the signal side of a normal, autoparts shop 12V relay. Use the switched (high amp) side of the relay to make/break the earth connection to the maggie P post. Use a normally close relay, good quality. No power to the old coil line, relay is shut, maggie is earthed, and no firing. Turn the keyed ignition switch on, old coil line has +12V, relay opens, maggie is no longer earthed, and ready to fire.
    If you have fixed timing, it's handy to put a normal toggle switch in parallel to the earth though. Toggle switch off, maggie stays earthed. Turn the key, spin the motor to starting RPM then flick the toggle to let the maggie fire. Gives the engine a few more RPMs so that the fixed timing advance is able to be tolerated on startup. Helps prevent the engine firing early in the compression stroke and trying to run backwards like an old Fergy kero-burning tractor.
    Cheers,
    Harv
  28. Hollywood-East
    Hollywood-East
    I've had zero issues an ran one (old Vertex) on a blown 327, Currently own three... Now if you're running no hood an it rains... That's another story..
  29. deathrowdave
    deathrowdave
    from NKy
    I spent big $$$ to get one recharged , advance installed , correct mag tach and ign switch to ground it . It wasn’t much for everyday driving . The electronic high energy ignition , with a vacuum advance is the best bang for the buck for your street driving . It’s really tough to beat , proven by millions of cars driven billions of trouble free miles . I agree nothing looks better , keep the hood closed and enjoy driving it and not tinkering with it .
  30. Besty34
    Besty34
    I was given a Joe Hunt mag/hei that had kept failing, I’m no mag or even electrical wizard but I figured the coil was killing the Mallory module so I removed the coil, made a spacer to replace it and fitted a standard 12v coil with a ballast resister. I drilled through the base of the mag and ran the ht lead through the hole . I run a early Hemi so the mag is at the back of the engine so I could mount the coil out of sight under the dash. I have had this on my car for about 4 years with no problems. [​IMG]
