Running an automatic with a 6x2 intake?
Discussion in 'The Hokey Ass Message Board' started by oldsrocket, Jan 7, 2010.
  1. oldsrocket
    oldsrocket
    Planning on running a 6x2 cross-ram intake on my poncho motor. Have been leaning toward an automatic transmission on this one (TH-400). But I haven't messed with 6x2 intakes a whole lot to know how to treat it.
    I'd love to see some pictures of 6x2 linkages/brackets that allow for the detent to work. Also interested in seeing how vacuum line to a cross-ram would work out....
    I have a eelco progressive linkage and I'll be running ford 94s.
    Any advice and or pics on the topic would be cool. Thanks.
  2. jerry sezar
    jerry sezar
    Hi,
    I've had 6x2's, Ford and Holly 94's on a Edelbrock X1 with progressive linkage on my '34 Vicky for 30+ years and I've never had a problem. Got a Chevy motor but the carbs don't know the differance, so the Poncho should run fine. I run a B/W T10 4sp and 9" Ford rearend. Depending on how wild of a camshaft you are using the vacuum requirement could be an issue. Lots of solutions availible, pumps, transmission modifications etc.
  3. oldsrocket
    oldsrocket
    Thanks. I'm more interested in seeing what solutions people have come up with as far as bracketry and such to make the automatic setup work well.
    Not too worried about the actual 6x2 setup and carbs. I know that will work, haha.
  4. shifts
    shifts
    Talk to Plowboy, hes running 6x2 on his bubbletop w/ a th400. Dave
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Every TH400 I've seen uses an electric switch to activate the kickdown feature, and many of them are actuated by the throttle pedal linkage underneath the dashboard. Shouldn't be difficult, no matter how many carburetors you're running.
  6. Mr Haney
    Mr Haney
    talk to coldwar.........oh sorry forgot he has been banned. He helped me out with a 6X2 crossram on my poncho motor. we used two sets of eelco 3x2 linkage for mine. crossram likes idle circuits intact. you will need to tune each carb seperatly. the linkage ****ed *** ! ! had to **** around with it extensively to make it work. coldwar spent many hours on his clock lathe makin ****.
    end result was VERY rewarding.....check it out for yourself
    http://www.youtube.com/watch?v=ent9rWJ-27w
  7. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    ^Yup, what Heathen said. Go find a TH400 car (BOP and Caddies from the mid 70's and below would be good choices) and grab the linkage under the dash. It's just a simple slide switch- it'll all make sense when you see it.
    BTW- I'd love to see that manifold on the Poncho mill! Got pix?
  8. PonchoJohn
    PonchoJohn
    from Fresno, Ca
    Mr.Haney- That's an AWESOME video! That was a sweet lil ride!
  9. Mr Haney
    Mr Haney
    thanks dude
  10. oldsrocket
    oldsrocket
    cool vid. Where do you live? Looks like the midwest. I'm pretty sure Coldwar was here in Ohio if I remember right. What the heck did he ever do to get banned. Seemed like a real nice guy the times that I talked to him.
  11. AllSteel36
    AllSteel36
    In my '57 I have a TH400 and used the kickdown switch mounted on the intake from a '70 Vette.
  12. Mr Haney
    Mr Haney
    we live close to dragway 42. see you there next season . drink some beers
  13. sixpac
    sixpac
    from Courtenay
    I run 6x2 intake with the holley 94s on my 348 in a 28 ford sedan 2400 lb car no kickdown just drop her back to 2nd and go. I am using a turbo 350
  14. Plowboy
    Plowboy
    The Hemi in the bubbletop is such a torque monster that I haven't really needed a kickdown. When I put my foot to the floor it just keeps going faster. The Turbo 400 that Dave (shifts) built for me does have an electric kickdown, I have it all wired up to a switch hooked to the gas pedal, but I haven't really worried about adjusting it so it works because, so far, I haven't experienced a need for it....
