Technical Running board bolts
Discussion in 'The Hokey Ass Message Board' started by Big mike 1968, Aug 3, 2021.
  1. Big mike 1968
    Big mike 1968
    Good morning, I have been looking for a source for running board bolts for my 1947 ford truck. I've looked online and this morning I called Dennis Carpenter's. They were extremely polite and tried to be helpful and the gentleman gave me the part number for a running board kit. I immediately went online to place an order and when I entered the part number the description came back as a 193? To 1947 car. I looked at the photos of the listed part and although somewhat similar, were not the same as what I need for my truck. What I would like to know, are the bolts for a 1947 car and a truck actually the same and maybe the description picture was just generic? Or do the cars and trucks have different hardware? Thanks. Also this is a pic I found, but is what my bolts should look like. They have a much bigger carriage head to thread profile. Screenshot_20210803-075110_(1).png
  2. pprather
    pprather
    Big mike 1968 likes this.
  3. 5window
    5window
  4. Big mike 1968
    Big mike 1968
  5. Big mike 1968
    Big mike 1968
  6. HOTRODPRIMER
    HOTRODPRIMER
    I just used regular carriage bolts from ACE Hardware on my '32 pickup running boards, but there is a slotted area under the board and they don't go through the board itself . HRP
  7. Big mike 1968
    Big mike 1968
    Yes Sir, I've been thinking that a might have to use regular bolts, but with the size bolts it would take on my truck I would have to drill my brackets and and the bottom of the running boards out to 1/2 inch from 5/16 inch. These trucks have a stepped shank.
  8. Doublepumper
    Doublepumper
    from OR-WA, USA
    Those particular running board bolts are unobtanium.
    They will have to be made or the running boards can be slightly modified to use a carriage or ****on head bolt.
    PM inbound BIG Mike.
  9. Big mike 1968
    Big mike 1968
    I was kind of scared of that, but also preparing myself just in case. Thanks
    pprather likes this.
  10. 5window
    5window
    https://www.earlyfordstore.com/collections/1942-1946-1947-ford-truck-parts These guys say they have used parts? Maybe check with them or something similar. How many bolts do you need. With a lot of work, you could get larger bolts, turn down the head diameter, turn down the smooth step then re-thread the shank to your thread size. Or find someone with a CNC machine.
  11. Big mike 1968
    Big mike 1968
    Thanks, I will check on that this afternoon.
  12. Mr48chev
    Look for "elevator bolts" at a good bolt supply source.
    These are for the bucket elevators that lift grain or other loose material up. Elevator bolt.jpg
  13. Big mike 1968
    Big mike 1968
    Thank you, those look promising with that big head. I'll check it out this evening.
  14. 5window
    5window
    They do have larger heads than carriage bolts, but most of those I have seen are pretty flat on top, not rounded like carriage bolts.
  15. PHuscher
    PHuscher
    If you want a rounded head, like a carriage bolt, but with a wider head, look for "step bolts".
  16. Big mike 1968
    Big mike 1968
    I will check that right now. thank you
  17. Mr48chev
    Now I have to go look at how Ford running boards bolt on On the 47/54 Chevy the bolts slide into a slot on the bottom side of the board and the head doesn't show though the board. Never ***ume. Finding a 47 FORD running board on the net the heads show on top of the board. That's my smack head moment for the day. It's going to need to be the right size square on the shank along with preferably 47 Ford running board.jpg a round head with no marks.
    5window and Big mike 1968 like this.
  18. Big mike 1968
    Big mike 1968
    The Fords 42-47, I believe, have a large hole in the top of the board. The bolts are stepped so that the clamping force is applied more to the bottom of the board so as no to crush the top. The top of the bolt head looks to be the equivalent of about a 1/2 inch carriage head and under the head is a shallow square shoulder and under is a round shoulder that steps down to a 5/16 inch thread. I hope this makes sense. Thanks for you reply.
    Mr48chev likes this.
  19. Doublepumper
    Doublepumper
    from OR-WA, USA
    ^ Typing at the same time.
    On the these trucks the running boards have box channels welded to the bottom. The bolt has a shoulder that presses against the bottom of the box channel, clamping it to the running board brace. Doing it this way avoided crushing the bolt head into the top of the board. So, yeah, they need a specific style bolt to make it work as intended.
    Unfortunately, these particular bolts are unobtanium as far as I'm aware.
  20. Budget36
    Budget36
    How about trying the place/gent who took over for Ray Naciwitz<sp>he had bolt kits for many early Fords. Someone on the FordBarn should be able to give the contact information.
  21. Doublepumper
    Doublepumper
    from OR-WA, USA
    ^ I checked with him...nuthing.
    What I've done, is to insert a tight fitting strip of nylon into the boxes, filling the void. With the boxes now filled, a ****on head bolt and washer can be used, without crushing the top of the board. I used stainless hardware and it turned out ok.
  22. Mr48chev
  23. Big mike 1968
    Big mike 1968
    Thanks again. I will have to do something similar when I get to permanently mounting them. I was trying to order bolts ahead of time so I wouldn't be waiting later. Right now I'm just mocking them up with regular 5/16 bolts with flat washers.
  24. Doublepumper
    Doublepumper
    from OR-WA, USA
    There are some tough parts to locate on these heaps and very little info.
    They've never been as popular as the earlier and later models and are just different enough to cause challenges.
    You'll work around it. It's only a hotrod:D
  25. Big mike 1968
    Big mike 1968
    Did you see my post in the what you did on your car today? My truck is not original my rear fenders are 48 and I cut and welded the running boards to fit. I still have a little bodywork to do where the fenders meet the bed but they are looking pretty good so far. I even thought about inserting threads on the plates on the bottom of the running boards and running regular hex bolts or Allen heads from the bottom. Then I could fill and smooth the tops. Maybe maybe not. Its all fun. 20210803_163904.jpg 20210803_145829_(1).jpg
  26. Doublepumper
    Doublepumper
    from OR-WA, USA
    Looking good. Factory rear fenders.....***etabou***.
    Keep your eyes peeled for old truck bed utility trailers, you may get lucky.
