Running Board,what glue for top pad?
Discussion in 'The Hokey Ass Message Board' started by 37 caddy, May 27, 2013.
  1. 37 caddy
    37 caddy
    from PEI Canada
    On my 37 caddy,i need to finish my running boards,i have a repro set of rubber strips to put on them,it is made up of 4 different peices,what is the best kind of glue to use,i know a contact cement is propably best,anyone have a brand recommendation?.I know this is a bandaid solution,but it is all i can get for this car,cant afford some of the rubberized sets that some can do. Thanks Harvey
  2. BJR
    BJR
    When I re did the running boards on my 32 Hupp I used a rubber cement that was supplied by the same place that sold the covering. I would think any supplier that sold running board covers for any make would have the correct glue.
  3. Allmotor
    Allmotor
    I used 3M contact glue on the Chevy's I built in the past. Worked well with no problems.
  4. HOTRODPRIMER
    HOTRODPRIMER
    I've always used a contact cement type,,3M or something similar.make sure you use it on both surfaces. HRP
  5. scrubba
    scrubba
    3- M makes a "Black " contact cement that I have used in the past for re attaching weather stripping . As it's been mentioned already, apply a small amount to BOTH surfaces before applying the parts together ! scrubba
