Technical running hot 210 degrees mild weather
Discussion in 'The Hokey Ass Message Board' started by fastcar1953, May 12, 2024.
  1. RMR&C
    RMR&C
    from NW Montana
    Checking the timing/tune first could save you a lot of time and expense
  2. gene-koning
    gene-koning
    We will be watching.
    fastcar1953 likes this.
  3. spanners
    spanners
    Running down the freeway you don't even need a fan, if anything the fan is creating unnessasary turbulence. The radiator is the bit doing all the work so get it right before throwing other stuff at it.
    The other thing to consider is the size of the pulley on the water pump. At 70 m.p.h. It's spinning it's freckle out and cavitation the coolant.
  4. fastcar1953
    fastcar1953
    Ok so the damper has moved on the crankshaft. Timing is off.
    vac***n advance was stuck.
    Starting the timing thing all over. Guessing the heating and bad gas mileage problems will be solved.
  5. gene-koning
    gene-koning
    I'm thinking I'm agreeing with you.
    You are on the right track now.
  6. fastcar1953
    fastcar1953
    I got it apart. Will finish tomorrow and check timing. 441537378_7992794557411427_4554013068105989199_n.jpg 445437028_7992794204078129_386416446731002702_n.jpg
  7. gimpyshotrods
    gimpyshotrods
    The correct temperature for a SBC, for complete combustion is 205F.
    210F is just fine, and is within the accuracy range of most gauges.
    If you insist on running under 200F, you will lose both power and mileage.
    Modern fuels make reading plugs a near useless exercise. If anything, your plugs being light brown is a clear indicator that this engine is running just fine the way that it is.
  8. lippy
    lippy
    from Ks
    My experience is, low speed no problem, high speed, radiator plugged. Coolant flow low.
  9. gene-koning
    gene-koning
    Then add: Timing retarded, incorrect ignition advance, lean fuel mixture, poor air flow through the radiator, air flow blocked by fan/shroud, air restricted from exiting from under the hood, slipping transmission/clutch.
