Art & Inspiration Running plug leads
Discussion in 'The Hokey Ass Message Board' started by Barrelnose pickup, Jan 22, 2021.
  1. TCATTC
    TCATTC
    A few carriage bolts jam nuts and zip ties
  2. triumph 1
    triumph 1
  3. Thanks for all the replies, I’m running 7mm wire as that’s what the flamethrower terminals are designed for but aren’t happy the way it looks , just looking for ideas as awhile to go yet.
    It’s going in a 30 Coupe with open engine so would like it to look tidy.
    I going with cloth covered wire, early style 90degree plug ends and straights into the distributor.( the plan anyway, they change though)
    I can’t just walk into a parts joint down here and pick from a selection of peices unless I go modern style regarding separaters,leads and terminals, even then most are fluro kits for common 8s
    Even getting the cloth covered wire , 90s and br*** wire ends was a struggle as not much stock with what we have going on. I couldn’t even get the straight boots for the distributor as no stock.
    The pic is in the run stand so the manifolds won’t be used , going with headers.
    Like I said thanks for the replies,much appreciated.
  4. Ziggster
    Ziggster
    Ford got it right with the earlier flatheads and the front drive distributors.
  5. X38
    X38
    Did you try here? :
    https://brillman.com/
    kadillackid likes this.
  6. Thanks but I saw this via another thread a few days ago but most distributor boots are around 3/4” ID on the large end whereas the Flamethrower plates suit a 5/8” ID boot.
    Brillman don’t give these sizes,only the wire size that I could see anyway.
    I will have to email them and ask.
    loudbang and kadillackid like this.
  7. Norris McCarty
    Norris McCarty
  8. Blake 27
    Blake 27
    I used pretty standard routing for my SBC, however I used some spring steel clips to hold the wire separators in place.
    I can easily unsnap the wires to gain room to remove the distributor or the cap.
    Under the ram-horn I used an available bolt hole to hold a home built stainless bracket to keep the wires in place. HPIM0204.JPG HPIM0206.JPG HPIM0209.JPG
    loudbang, egads, bchctybob and 2 others like this.
  9. saltflats
    saltflats
    from Missouri
    Take some thinner and remove the lettering from the wires.
    I worked at Taylor cable company for a spell during tech school, I couldn't wait to get out of that job.
    loudbang, bchctybob and kadillackid like this.
  10. Blake 27
    Blake 27
    These pics were taken pre-detail (note primer). I did remove the lettering..LOL
    I used brake fluid, worked well.
    loudbang, kadillackid and saltflats like this.
  11. lumpy 63
    lumpy 63
    Hey Chris , glad to see your Caddy project is moving forward:D I finally lit mine off the other day. Cant help much with wire routing as I used 1951 covers with the factory loops welded to the outside of the covers to route the wire's .
  12. seb fontana
    seb fontana
    from ct
    Click on pic to enlarge farther!
  13. DeLuxe 32
    DeLuxe 32
    The factory bracket on this Caddy does a good job, but it does detract from the rocker cover, especially if chromed, in my opinion.
    loudbang, warbird1 and bchctybob like this.
  14. Flathead Dave
    Flathead Dave
    from So. Cal.
    What type of shifter is on this?
    bchctybob likes this.
  15. DeLuxe 32
    DeLuxe 32
    Some more
    loudbang, warbird1, lumpy 63 and 2 others like this.
  16. Thanks Colin, great to hear you got yours fired up. All good?
    I got mine running a few months back and are stoked! Ran really good on the run stand, fired it with original distributor but wanting to sort properly with the Spalding.
    Cheers Chris
    loudbang and lumpy 63 like this.
  17. Hi Jeremy, gotta get that 390 up here and get it run up sometime. Did you get you intake sorted?
  18. warbird1
    warbird1
    I remember those things from my Y-block days; usually oil soaked and jammed up against the firewall. Fun times...
    loudbang and dana barlow like this.
  19. chevyfordman
    chevyfordman
  20. Blake 27
    Blake 27
  21. Bandit Billy
    Bandit Billy
    On my flathead I am running chrome tubes and Brillman cloth covered, carbon core wires with rajal terminals.
    loudbang, dana barlow and egads like this.
  22. Jalopy Joker
    Jalopy Joker
  23. Got it done, happy enough for now, thanks for the input. ED44D8BE-2956-4120-A61C-14DF4C541A7F.jpeg F17D8EBB-621B-4096-A70F-C61E558D9C1B.jpeg
  24. kadillackid
    kadillackid
    Perfecto :rolleyes:....awesome job !
    Barrelnose pickup likes this.
  25. jimmy six
    jimmy six
    Black wires. If you can find the early covers that held the front 4 cylinders of your SBC against the block use them and paint them the color of the block. Tuck them all down off the distributor cap to behind the heads. The less you see the better for me.
    Ford Y-Block holders can be used on a lot of engine to keep the wires spaced and hidden.
  26. Hollywood-East
    Hollywood-East
    KIMG9950.JPG My approach.. bought a bunch of old stock grommets on the auction site, An some aluminum flat stock from hardware store... KIMG9951.JPG
