Running rear drum brake lines
Discussion in 'The Hokey Ass Message Board' started by unkledaddy, Sep 29, 2009.
  1. unkledaddy
    unkledaddy
    Does anybody have a trick way (without welding) to attach hard brakelines to a smooth Ford 9" for a short distance (from the drum backing plates to just inside the frame rails on either side)?
    Any pix?
  2. HOTRODPRIMER
    HOTRODPRIMER
    The only other way I know of is to drill and tap or use self taping screws and a brake line clamp like you use down the frame. HRP
  3. westcoaster
    westcoaster
    from SoCal
    hard lines from the backing plates to frame rails???
  4. jimi'shemi291
    jimi'shemi291
    While we're on the subject in the back end, whose a good maker of the FLEX brake line in these set-ups? I don't want to put sub-grade foreign part in such an important role on my '55. (Didn't mean to hi-jack, but it seemed to tie in, guys!)
  5. unkledaddy
    unkledaddy
  6. unkledaddy
    unkledaddy
    where they'll connect to flex hose.
  7. as already said , drill and tap for 10-32 screws and use clamps
  8. unkledaddy
    unkledaddy
    How much meat on the axle housing? I don't want to drill through.
  9. Shifty Shifterton
    Shifty Shifterton
    You're going to drill thru or the threaded engagement won't be sufficient. Use sealer.
    Personally I just tack a few strips of heavy sheetmetal to duplicate factory style fold-over tabs.
    Why are you running dual lines? IMO it's more h***le and less clean looking than a single.
    Good luck with the project.
  10. fiftyv8
    fiftyv8
    from CO & WA
    I just made up some sheet metal tags similar to OEM and mig welded them onto the housing.
    A quick grind up and they look like original and where I wanted them.
  11. unkledaddy
    unkledaddy
  12. jimi'shemi291
    jimi'shemi291
    Thanks UncleDaddy for the TIP! As for the ocnnections, lots of solid recommendations here! The whole thing is about making it look good and making the fasteners prevent vibration that will cause stress and leaks.
  13. Terminate the hard line on left and right inner frame rails and use a black rubber brake hose from the lines directly to the left and right wheel cylinders.
  14. unkledaddy
    unkledaddy
    I'll entertain that thought. Thanks.
