Projects Russian dolls
Discussion in 'Traditional Hot Rods' started by edwardlloyd, Nov 9, 2014.
  1. Can't wait to see more!
  2. edwardlloyd
    edwardlloyd
    from Germany
    I've not used a Smart MC before so it's going to be a "**** it and see".
    But if does work I'll do a Tech on it.
    You'd pay 5 times as much for a Made in China aftermarket set up. I'm very wary of aftermarket parts, especially safety relevant parts. Obviously the Smart part is 100 times better built.
    We 'll see. Maybe it won't work.
    Ed
  3. falcongeorge
    falcongeorge
    from BC
    X 2 on the frame, slicker than goose poop.
    volvobrynk likes this.
  4. jcmarz
    jcmarz
    from Chino, Ca
    I thought this thread was for mail order brides.
  5. Outback
    Outback
    from NE Vic, Oz
    HAHAHAHAHA...
    Seriously though, what a great project, I'll subscribe and watch the antics!
  6. edwardlloyd
    edwardlloyd
    from Germany
    [​IMG] First install of the engine to work out what needs cutting to fit.
    kiwijeff, cully33 and volvobrynk like this.
  7. edwardlloyd
    edwardlloyd
    from Germany
  8. 3wLarry
    3wLarry
    from Owasso, Ok
  9. lothiandon1940
    lothiandon1940
    Liking where this is going.:).........That open valley under the Buick intake sure came in handy.:D
    kidcampbell71 and volvobrynk like this.
  10. cully33
    cully33
    Doing a great job, love the way you are thinking outside the box, and what a mint body. Will be watching for sure.
  11. ct1932ford
    ct1932ford
    There are russian dolls and there are Russian Dolls:rolleyes:
  12. edwardlloyd
    edwardlloyd
    from Germany
    Umm. What's going to look better in 60 years time?
  13. Does the starter bolt to the transmission or the block?
  14. Bam.inc
    Bam.inc
    from KS
    Subscribed. NAILHEAD & dolls & 32 frame.... wasn't even going into this thread, but I had to look behind the curtain. Now im hooked
  15. edwardlloyd
    edwardlloyd
    from Germany
    To the block. You can see it in the picture above.
  16. edwardlloyd
    edwardlloyd
    from Germany
    This is the Smart brake pedal. I flipped and shortened the box and mounted it on the left X-rail. The floor board will cover up the box and most of the rubber boot too.
  17. A Boner
    A Boner
    Why not use a TH 350 transmission with the BOP& Chevy bolt pattern? Don't know how rare they are, but I found one for my modified.
  18. edwardlloyd
    edwardlloyd
    from Germany
    Because of the power and weight of the engine, I didn't want to simply add little mounts on each sice of the frame. Remember this is a riveted open channel frame with a riveted in X-member. I wanted an engine cradle. So in keeping with the '40-'48 Ford/Mercury frame concept, I dug out a '48 front crossmember and started looking at it. It needed narrowing of course, about 1" per side, then fitted nicely. The lower engine mounts are made out of the cut off '32 front frame horns - waste not - want not!
  19. edwardlloyd
    edwardlloyd
    from Germany
    As you can see I'll have to fill the holes in the inner X in a couple of places to enable me to bolt the cradle in place.
  20. edwardlloyd
    edwardlloyd
    from Germany
    The RH mount on the Buick is further forward than the LH making a slightly different lower mount necessary. I used the original Buick engine mounts.
  21. edwardlloyd
    edwardlloyd
    from Germany
    And here we have it. Engine securely mounted using only old parts. I'm decided to use a Unisteer rack up front and will mount it on this crossmember. Later the crossmember will get lightening holes but first I need to mount the steering box.
    volvobrynk and 3wLarry like this.
  22. AHotRod
    AHotRod
    A real Hot Rod in the making .......... Priceless!
  23. Why a Unisteer rack?
  24. belair
    belair
    Great vision and execution.
  25. Runnin shine
    Runnin shine
    Ed I might not have said this before... you are a fine craftsman.
  26. Baumi
    Baumi
    Hey Ed! Awesome thread and great work ! I like how you think outside the box!
  27. edwardlloyd
    edwardlloyd
    from Germany
    Well I've used them before and I like them. They give a nice positive steering feel. Also it seems to fit the available space best. The left hand engine mount sits where a Vega or Ford side steer box would need to sit, and there's no room for an F1 or F100 either.
  28. chubbie
    chubbie
    The Nailhead isn't a BOP...
  29. B uick
    O lds
    P ontiac = "not BOP"?
    What bolt pattern did the Nailheads have? Chevy, Ford, Chrysler? I'm confused!
  30. flatoz
    flatoz
    wingnutz BOP is a later version of stud pattern. think more 455 Olds, Buick etc. the Nailhead is the same era as the 324 rocket Olds, they don't interchange. I don't know 100% but think that the BOP was late 60's
