wasn't there some one on the board that was a distributor for this stuff? if so could you e-mail or PM me thanks RACEFAB
RUST BULLET is a one step- 2 coats, super tough, high performance rust inhibitive coating. I just picked some up from FartCat and Enjenjo for Big Olds. After examining Big Olds's rear end the other nite, I noticed all the surface rust that has started on just about everything since my return from B'ville. It was $30 for a quart, which I was told I will be able to do the whole underside, inside trunk area, and inside passager areas. order yours here Hopefully this product will take care of the problem. I'll do a product update in the spring and tell you guys if it worked.
thanks for the quick e-mail fatcat, i tried to order from the site that you gave me the link to. i sent you an e-mail explaining my problem i am having. as far as the other products, i have tried both, por=15 and zero rust, i now want to give this product a try, thanks for the responses RACEFAB
