Rust on gears
Discussion in 'The Hokey Ass Message Board' started by Truckedup, Nov 1, 2009.
  1. Truckedup
    Truckedup
    Yes,rust on gears,but how much rust is too much? I rebuild a few standard ******s a year,no expert here,but good enough so they work as they should.I'm putting together a Saginaw that has some rust on the gears.Normally I just toss out rusty **** but this is a budget build for a 200 HP engine.The photo show the rust on the teeth of the clutch gear.It's mostly discoloration but there are some minor pits as you can see.There's also some rust on a few other gears,but this is the worst one.
    What do you think? Run it see what happens??
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Run it !! A few rust pits ain't gona hurt . Now flaking/gaulded would be a different story as metal fatigue was starting.
  3. Dragons
    Dragons
    from Topock,AZ
    I've run way worse.
  4. Bullet Man
    Bullet Man
  5. gimpyshotrods
    gimpyshotrods
    Yup, run it. I have put 50k and counting on way worse. Just clean it really well first, so there are no loose bits.
  6. axeman39
    axeman39
    from Saco Maine
    I have some Saginaw parts from various 4 speeds I have dis***embled over the years, If there is anything you need let me know.
