Technical Rust prevention
Discussion in 'The Hokey Ass Message Board' started by Hotrodjohn71, Feb 10, 2026.
  1. Hotrodjohn71
    Hotrodjohn71
    What is recommended for rust arrest/prevention inside of an enclosed window pillar on A pillar?
    Id like to spray in something to prevent rust or more rust in sections I cannot readily get to.
    Thank you
  2. Bugguts
    Bugguts
    If there is an access hole,or holes. I would use 3M Cavity wax and the appropriate extended wand, which sprays a wide mist of wax in all directions to coat and block air and water from contacting metal. The wax hardens some when dry and works well.
    Always spray after paint and bodywork to prevent panel contamination.
  3. 1pickup
    1pickup
    I used this on the inside of my frame rails. Should work for your purpose as well.
    Hotrodjohn71 likes this.
  4. evintho
    evintho
    If you can get a brush down in there, POR-15 works quite well. I coated the inside of my rocker panels before welding on the top section.
  5. Hotrodjohn71
    Hotrodjohn71
    Thank you for great suggestions.
    The areas I would be wanting to treat would be totally unreachable (except for a probe tube like 1pickup showed.
    There would more than likely be a little surface rust within.
    Thanks
    John
