Rust removal by electrolysis???
Discussion in 'The Hokey Ass Message Board' started by rex1927, May 1, 2009.
  1. KrisKustomPaint
    KrisKustomPaint
    Another tip I've found out is taking milk crates and cutting them apart so you have 5 squares of plastic. Use them to keep parts separate from the anode. That way you can just set the sacraficial metal in the bottom lay down a couple of pieces of the milk crate "grills" and set the part on top of that.
  2. CharlieLed
    CharlieLed
  3. weldtoride
    weldtoride
    Mol***es works, my son and I have good luck with 1/4 mol***es/water. Google it, its popular on other threads. I get it at local feed store, here its $3 gallon as feed supplement, grocery store is way too $$. Nothing the EPA can stab you for using it either.
