Rust Removal with Baking Soda Mixture
Discussion in 'The Hokey Ass Message Board' started by rodknocker, Feb 6, 2007.
  1. polisher
    polisher
    Alliance Vendor
    Won't harm chrome
  2. polisher
    polisher
    Alliance Vendor
    You should not use stainless, that will put nickel and chrome into the bath which then makes it controlled.
    Also any fume with nickel in it can cause pulmonary edema.
    It is a pretty serious condition that kills 4 out of 10 people that go down with it.
    Any regular iron or steel will do.
  3. polisher
    polisher
    Alliance Vendor
    Works by line of sight, so you would need auxilliary anodes to the inside of a body.
  4. 1952henry
    1952henry
    It's just Red Devil Lye, used for drain cleaning. Many hardware stores have it, sometimes by a different name. Thanks to the cranksters, it is a little more difficult to find than it was two years ago. Wear gloves, as it will remove the skin from your hands as well as the paint from the part!
  5. Dirty Dug
    Dirty Dug
    I think I'll just take it to the blaster instead but thanks for the suggestion....
  6. 53chieftian
    53chieftian
    I know what I'm gona try tomorrow! This sounds way cool!
  7. Primo
    Primo
    Will an auto-shutoff battery charger work?
  8. bob41
    bob41
    check out may 2007 r&c for a article on this , I used this process and have had good luck with it.
  9. CaddyRat
    CaddyRat
    This is awesome!
  10. Try your local hardware store with the drain cleaners.
  11. polisher
    polisher
    Alliance Vendor
    Stainless is next to useless, it has the iron removed.
    Plus the fume can cause pulmonary edema, and the waste is controlled because it now contains nickel and chrome.
    Good old backyard iron gives the best results.
  12. zimm
    zimm
    from iowa
    sorry to dig up an old thread but could i safely clean the inside of a 18 gallon gas tank without putting the hole tank in a large platice tub?
