Rust Removal
Discussion in 'The Hokey Ass Message Board' started by lilbill, Aug 14, 2004.
  1. lilbill
    lilbill
    from arkansas
    my '52 has a coat of rust all over the body where the paint has weathered away. i don't have access to media blasting so does anybody have any tips on how i can treat or remove the rust so i can paint the truck?
  2. delaware george
    delaware george
    from camden, de
    i wish i had a good tip for you...i just started to work on our 53 and it looked pretty good,but i found a ton of things that'll be just better to replace...good luck [​IMG]
  3. autocol
    autocol
    tool #1: an angle grinder with a wire brush. it will eat that surface rust for breakfast without taking away much else. don't stay in one spot for too long as the friction can generate some heat, and the heat can generate some waves...
    tool #2: a paintbrush, and a can of (relatively dilute) phosphoric acid. what you can't physically attack with wire you can eat with acid, and by using phosphoric you leave behind a rust-preventing coat of phosphorsomethingate as part of the deal.
  4. kustombuilder
    kustombuilder
    from Novi, MI
    YEAH, what Autocol said. there are also these paint and rust stripping discs they sell at alot of places around here that you can chuck into your drill and go after the rust. it looks like it's made of some ******** Scotchbrite material. a friend of mine found some on the interenet somewhere that he could mount in his angle grinder and they work MUCH faster. they leave a real nice surface on the metal and don't generate alot of heat. the ting is you wanna stay away from the edges cause if you catch an edge it tends to tear the wheel up rather fast.
  5. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    3M makes these nice scotchbrite disks. Its looks like a black mesh, its hard but very flexible.
    they come in purple and black. Ill get the info. You can put these on a drill or grinder and it will pull all of the rust off w/out damaging the metal.
    Click on this link...this guy knows his stuff.
    Browse the website, the makita he has works well w/ these disks. Strip-it Disks
    Here is a pict of one.
  6. chad
    chad
    I've used them 3-M ones lotsa times.They work really well.
  7. Roadsters.com
    Roadsters.com
  8. kustombuilder
    kustombuilder
    from Novi, MI
    not really tech but great info. we should get this moved to the Tech-O-Matic...
