1952-59 Ford Rusted Out Trunk
Discussion in 'Off Topic Hot Rods & Customs' started by Old Patriot, Oct 18, 2010.
  1. I pretty sure that there are no reproduction panels (at least I can't find any) for the 54 trunk that has rusted out, so what have you done to fix this problem? What have you used and how? Thanking you in advance.
  2. 10bucks
    10bucks
    I have a 2-door parts car sitting in front of my shop that has a very good trunk floor in it.
  3. mikhett
    mikhett
    from jackson nj
    I got some 20 ga sheetmetal and welded it in after putting some beads in it on my friends bead roller.I eliminated the spare tire well as its gonna b a kustom anyway.I used my Hoibart 140 mig.
  4. Thanks guys, that is what I figured, either a parts car or fit sheet metal. 10bucks, your a little to far to use a whole car, but if you cut the floor out, what would you charge for the piece? Shipping would kill it too, probably.
  5. Retro Jim
    Retro Jim
    Mine is OK but I will have to replace mine in my 50 Ford . I am going to do away with the spare tire hole and just cut out the bad and make a pattern on cardboard for new one . I have a bead roller to roll some beads to make it stronger . Then I will just weld it in . They make one for my 50 Ford but way cheaper to make one yourself , if you have the tools to do it or maybe a friend can help.
    If you don't have a bead roller . get a piece of hard wood from someone that has a fireplace , make a notch/cutout in the log about 6-12" long . Now draw the lines where you need to make a roll on the sheet metal then take another piece of word about 4-6" long and make a rounded edge on it about the width of the bead roller , now just use a mallet or hammer and start beating the wood on the line you made on the sheet metal . Just go back and forth till you get the pattern you want . That is the poor mans bead roller . You can also use the round end of a ball peen hammer , lay on the line on the sheet metal and use another hammer to hit it slowly . DON'T try to do it with one hit . It will work !
    Jim
  6. Thanks Jim, by the way MAC's has trunk panels for 50 Fords.
  7. Retro Jim
    Retro Jim
    OK thanks ! I know Macs and some other places have them and most come from EMS . I try to make what I can for the enjoyment of doing as much as I can by myself ! I am far from the best metal man but when I can save some money by making it myself I will . It's always nice to be able to tell people that I made that part myself and most will understand what it means to make and build the car yourself . Anyone with deep pockets can by a car and show it off but all they can say is they know where the gas goes ! But it takes someone with their own hands to build a car by theirself with lots of pride . There are some pieces that is very hard for me to make so I usually buy those . I am on a couple metal making forums and they are very helpful and if anyone has been to the Jalopy Showdown in Pa. then you know who many of them are . They are the ones that do the metal shaping under the pavilion .
    They also have a section on the sites where they tell you how to make many tools that will save you some money too .
    Anyway it's not that hard to make a flat piece for a floor or trunk . Just remember if you screw it in or overlap the piece and weld it in , just make to use seam sealer on both sides so water doesn't get trapped in side and start rusting again .
    Jim
  8. 10bucks
    10bucks
    Patriot, I'll be stepping out till the the weekend but I'll check it out when I get back and let you know.
