Rustoleum - how hot can you get it
Discussion in 'The Hokey Ass Message Board' started by HemiRambler, Feb 18, 2007.
  1. HemiRambler
    HemiRambler
    Anyone put rustoleum on tail pipes?? Seems like they don't get THAT hot. Anyone know for sure??
  2. Unkl Ian
    Unkl Ian
    I've baked Rustoleum on in the oven,at 400 F.No problems.
  3. I would suggest Eastwoods stainless heat paint...I have thinned it with laquer thinner and sprayed it on exhaust pipes then fired the car up to set it....works great and looks great too-fairly low cost as it goes a lot further sprayed than brushing it on does.....
  4. Hot Rod Surf
    Hot Rod Surf
    from San Diego
    I have a few friends who do that to their pipes, it fades in about a month or two if you’re a daily driver. So keep some in stock to keep reapplying.
  5. wavy
    wavy
    I used it on a 4cyl and had it flaking off in two weeks from the exhaust manifold to about 2 ft back from there it stayed fine
  6. atomickustom
    atomickustom
    We brush-painted the duals on my Dad's 390-powered '56 Vicky with white rustoleum in 1980. Most of it was still on there when he sold it in 1985. Did just like wavy said: peeled a couple feet back from the motor on each side and that was it.
  7. Petejoe
    Petejoe
    from Zoar, Ohio
    I always use the dupont engine paint for this. The stuff even keeps its gloss for a long long time.
  8. Shifty Shifterton
    Shifty Shifterton
    Most paint companies say it's OK to do the tailpipes, but not mufflers or forward of the muffs. I like POR20 and brush most of my systems before installation, then do the welds afterward. The silver is obnoxious at first, but mellows out after 6 months of use and doesn't burn off, even headers.
  9. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    ive painted my tailpipes on my daily with rustoluem flat black with no problems
  10. Scott B
    Scott B
    from Colorado?
    If you're good with black, the BBQ paint holds up fairly well on pipes. I have used it many times on motorcycle exhausts....
  11. DON'T use regular rustoleum on anything that gets hot. I painted my trans flat black and it g***ed off noxious fumes into my ****pit for weeks!
    BBQ black works well.. i used it on my headers no problem.
  12. Bugman
    Bugman
    I've got Rustolium on my exhaust tip. Been there for a year or so, with no problems. I've also used it on brake calipers with excellent results. Conversly, I used it on a VW header/muffler and you coult tell EXACTLY wher the hot spots were because the pipes and center of the muffler turned from satin black to white powder.
