Projects Rusty 47 Ford Reserection
Discussion in 'The Hokey Ass Message Board' started by koolkemp, Apr 17, 2010.
  1. I like what you did with the door bottoms. Its all those little touches that add up to make a great finished product. I'm liking the profile by the way, I think you got the proportions just right.
  2. koolkemp
    koolkemp
    Yep, the door bottom has an arch to it, and I dont have a brake or shrinker/strecher, and I was wondering how this would work so I decided to experiment, its super strong and there is still some space between the inner and outter panel where they meet. I drilled some drain holes on the inside skin and covered everything in weld thru primer as well . After the bodywork is done I will skirt it full of some type of concoction to prevent further rust. I finished the driverside outside skin today it went much quicker (2nd one always does ) .Should have the rest of that door finished tomorrow.
  3. koolkemp
    koolkemp
    Thanks Steve !It worked out better than I expected it to, was half expecting to be cutting it all off and starting over lol. The one thing I like about it is there is no folded seam on the bottom now to trap moisture .
  4. koolkemp
    koolkemp
    Where ya been hiding?, hopefully getting some time in on the T :rolleyes: Its great having some real electricity finally, no more stealing the dryer plug from the Missus and tripping breakers in the house . The backs still about the same, I have found that doing a 2-3 hr "shift" then resting inside for a while and coming back at it cuts down the pain quite abit I wont take more than 1 of the new painkillers a day they make me feel ****py if I do. I cant believe that welder is still chugging away, that noise still comes and goes I dont worry about it anymore when it dies it dies !
  5. pimpin paint
    pimpin paint
    from so cal
    Hey koolkemp,
    Your build is moving alot of people to rethink what's buildable!
    On the sheetmetal brake & shrinker/stretcher issue..........have you ever clamped sheet between two pieces of plywood or MDF and hammerformed them to shape? This is a great way to produce low-buck sheetmetal parts from some ply, clamps, a wooden mallet, a corking tool (wood or plastic) and some sheetmetal. You can form highly shaped parts using this method as well as rockers and lower skirt sections. Whenever I need a part with little or no shape I usually go the route vs. repop + shipping costs for a part that doesn't always fit as it should.
    Check the search deal ,here on the HAMB for hammerforming & also the online metalshaping sites like metalshapers.org.
    " Humpty Dumpty was pushed "
  6. I used the hammerform methods with great success on new panels between bumper and car.
  7. GizmoJoe
    GizmoJoe
    Hidin? Sorta. I've had 1 1/2 months of being really sick. Then mom was hospitalized with a nasty pneumonia. So I've had little to no time or energy. Been a rough year so far.
    But between the sick days I did manage to make a simple stand for the body, get a sub-frame from a phaeton chopped up to fit and mocked up the body.
    Oh.. and the ch***is is mocked up but rolls.
    Glad the new wiring is working... for you AND her. ;)
    Keep worrying about the welder and it will keep working. ;)
    2-3 hr shifts is reasonable. Gives you time to "reflect" on things anyway. It's a whole lot better than not being able to walk because of the pain. Trust me.
    You have to adjust or pay for it in the long run.
    Keep on keepin on!
  8. banditomerc
    banditomerc
    hey Steve,the door idea is great.You know all the tricks! keep it up,looking good.
  9. Hackerbilt
    Hackerbilt
    Incredible job Steve.
    I've used rod to outline hidden parts before but it seems to work well on an exposed edge too.
    Might end up doing the same thing to form my rear wheelwell lips on the Dodge.
    Thats gonna be a bit of a head scratcher right until I actually start on it!!!
    Hope both you guys start feeling better ASAP.
    The snow this year is ****py enough without being sick or sore on top of it!
  10. Bruce A Lyke
    Bruce A Lyke
  11. HambBurglar
    HambBurglar
    from Cincinnati
    KoolKemp
    You're an inspiration. This is exactly what drew me to the HAMB. I need to get out in the garage and get busy!
  12. koolkemp
    koolkemp
    I have never done anything with a hammer form yet...I could have tried it for the center splash pan on the rear , but what I did instead was make a cardboard template, traced it on the tin and cut it out leaving enough to fold over for the edges, used a small adjustable wrench to fold the edge and finished it up with a hammer and dolly...it went pretty quick, faster than it would have taken me to make the hammer form lol. I dont have much in the way of wood working tools, and am pretty impatient when I want to get something done . I will need to make one for something someday I know that for sure cause I do want to experiment with them. I will probably make some flush fit skirts and am contemplating a few different options right now. I havent even ***embled the E wheel I got a couple of months or so ago ..who has time to put tools together when the car needs work ! But I will need that for the skirts.
  13. koolkemp
    koolkemp
    Thanks Dave! You trace out one of those skirts yet :D ?
  14. koolkemp
    koolkemp
    Thanks Bill I am pretty happy with how it turned out, I finished the drivers door today and it went together pretty quick and looks great and is super strong. We went out to Chads for dinner(Nadines B'day and mine on Sat) so its too late and I am too tired to post post pics tonight I took a few pics at his place too.
    Well at least we are suffering together eh Joe ! I am glad you are getting something done, post a few pics up here in my thread if you want!
  15. koolkemp
    koolkemp
  16. youngster
    youngster
    from Minnesota
    Just my 2 cents but a Merc grill surround and a Plymouth grill bar would look ***s!!
    Ron
  17. Copper Top
    Copper Top
    Happy Birthday to you Steve and Nadine, hope you have a great weekend!
  18. Hackerbilt
    Hackerbilt
    Oh! Congrats on the double Birthdays! Thats really cool!!! :D
  19. Racrdad
    Racrdad
    Ok I just went thru every page of this thread and your dedication is inspiring to say the least. Count me in as a fan of this build and subscribed so I dont miss any progress. Go Man Go !!!!
  20. koolkemp
    koolkemp
    I guess we think alike cause I have been following yours as well :D Thanks guys, on the slippery slope to 50 now :eek:
    Didnt have any time to do anything today and its been ******* rain all day here but the ground is still frozen so the waters got no place to go ..got a rather large puddle in the shop when we got home tonight :mad: tomorrows the last I can work on it till next weekend,(after I try and clean up the water) ,going to Toronto for a training co**** for work this week ...oh joy ! Anyways heres a few pics from yest
  21. koolkemp
    koolkemp
    Damn I forgot to resize the pics sorry gimme a few mins...
  22. GizmoJoe
    GizmoJoe
    Happy B'day to you and the missus!
    Same day but she's a lot younger than you, right???
  23. koolkemp
    koolkemp
    Lol and she wont let anyone forget that !!Thanks Joe, lets try these pics again...
    the rest are still showing up full size even though I have resized them all...sometimes I hate photobucket I will try again tomorrow !
  24. koolkemp
    koolkemp
  25. koolkemp
    koolkemp
    Got all the trim holes welded up and finished up the chop seams ...
    kidcampbell71 likes this.
  26. GizmoJoe
    GizmoJoe
    Coming along good Steve.
    Forgive me if you've mentioned it but what plans do you have for interior?
    Are you able to do that too?
  27. flatheadfever
    flatheadfever
    Hey Steve
    Looking good!!
  28. koolkemp
    koolkemp
    Thanks man! You still in Norway ? I gotta go to Toronto for the week for a co****....
  29. farmer12
    farmer12
    Wow Steve, you're moving along nicely I see. Looking good and keep the updates coming.
  30. koolkemp
    koolkemp
    If you are asking me if I can sew the answer is no ,but I do know an upholsterer , gonna use the s10 bench for now and whatever I can cobble together for a back seat, its a long way from looking fancy on the inside I will be happy with some insulation and wood or plastic door panels!
