rusty nuts!!!lol
Discussion in 'The Hokey Ass Message Board' started by Jimv, Jun 2, 2005.
  1. Jimv
    Jimv
    I have a set of chrome lugnuts that are rusted & i want to soak them in something to remove the rust.
    Since i'm not working i was wondering if therews any household stuff I can soak them in like coke or something?
    i just want to remove alot of it, then i'll polish them by hand.
    Thanks
    JimV
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    In Cider !!
    Seriously....try vinegar, it has an acid that will eat rust.
    May take a while.
  3. jalopy43
    jalopy43
    I have used diluted(with water) muratic acid before. experiment with the ratios. You don't want to dissolve your NUTS!!:D Sparky
  4. The Catholic
    The Catholic
    from Akron Ohio
  5. myoriginal77
    myoriginal77
    I've used some stuff called "Gibbs" it's like a penetrating oil, try a yahoo seach or email me your address and i'll send you a can. frank@ittphoto.com
  6. flatheadpete
    flatheadpete
    from Burton, MI
    PB Blaster works. Or try a baking soda/water mix w/ lotsa soda.
  7. atch
    atch
    i can't remember what the metal was, now, but i soaked something in vinegar for a couple of weeks and the metal dissolved. check often if you use vinegar.
  8. evilgenius
    evilgenius
    i myself am a big fan of replacing rusty nuts and bolts whenever possible.
    matt
  9. polisher
    polisher
    Alliance Vendor
    AAAGH!!!!!
    No MUriatic!!
    Not if you want chrome !!
    It eats chrome in seconds.
    If you use that you'll be looking at nickel.
    Either use a quality polish like MPR or stick them in a reversal tank.
    1lb of Sodium carbonate or bicarbonate,
    (both work)
    plastic bowl of hot water.
    Doesn't have to be hot but hot is quicker.
    piece of steel on sides.
    Hook to battery charger, make parts negative,
    steel positive.
    Give it a few hours anything from 2 to 8 hours depending on parts.
    It will make rust back into iron with out removing chrome.
