Rusty slotted screw removal TECH Tip
Discussion in 'The Hokey Ass Message Board' started by cjo13, Aug 7, 2011.
  1. cjo13
    cjo13
    from SD
    I would like to test the waters out here, After unsucessfully finding a way to remove door hinge screws without "Screwing" up the hinges in some way I thought that I should see what Ideas are out there.
    I have tried Heating with a torch..... Impact driver....... Centerpunch and Drill (Never find the center..) Blasting out with plasma cutter... all to end up with not so desirable results.
    Please share any ideas that have worked for you.
    I have a damn nice set of '40 ford hinges I need to keep...
    CJO
  2. 32v
    32v
    from v.i.
    easy... weld a nother bolt to it let it cool whrench it out
  3. henry29
    henry29
    I usually use a nut and weld it from the center.
  4. otas
    otas
    Very nice! Always have the same results. Will def use your advise next time 32v.
  5. Da Tinman
    Da Tinman
    weld a washer to the screw, then weld nut to washer, let cool before turning, usually comes right out.
  6. cjo13
    cjo13
    from SD
    Never thought of that. That is what we are here for.. I will try this It sounds like a damn good Idea. I have welded a bead around the inside of an outer bearing race before and had it pop right out, never thoought of this. Thanks Guys!
    CJO13
  7. Yep. Thanks from me too.
  8. ironpile
    ironpile
    Grind out the center with a cone shaped burr and then drill it out .
  9. Da Tinman
    Da Tinman
    by the time you get it center punched and drilled I'll already have it on the floor LOL!
  10. 52pickup
    52pickup
    from Tucson, Az
    Welding a washer and nut has served me well. Air hammer with a pointed bit has saved me a couple times, too.
  11. 69fury
    69fury
    for little screws, a dollop of valve grinding compound will give a screwdriver a little extra grip .
    -rick
  12. dodgerodder
    dodgerodder
  13. 53Crestline
    53Crestline
  14. rdscotty
    rdscotty
    from red deer
    x2 I made this after seeing it on another thread. He's right. I couldn't believe how well it worked.
  15. HotRod60F100
    HotRod60F100
    Thanks for the tips too,some of the skrews to the trans cover in the cab of my 60 are rusted.
  16. Dznuts
    Dznuts
    from ATL jo ja
    THANK YOU. its def. a why didnt i think of that. been drilling my hinges out for days all the while thinking theres gotta be a better way!
  17. steveo3002
    steveo3002
    from england
  18. good idea but i'll stick with mapp gas and either beeswax or a mix of 50% ATF/50% ACETONE as this has worked 99% of the time. drill only comes out as last resort.
  19. Damn it I drilled my door hinges out already!!!!!
    Why didnt I found about it before???
  20. cjo13
    cjo13
    from SD
    Thanks for the Tool Idea, I am making one tonight. It looks like a GREAT idea.
    CJO13
  21. cjo13
    cjo13
    from SD
    Tried the air hammer trick last night. It does free them up and turn them, but the threads must have taken a hike as the screws just turn and do not back out. Round 2 with the drill tonight.
    CJO13
  22. Ed Wrath
    Ed Wrath
    Shame I saw this too late. Gibbs Brand Lubricant may have saved the thread. It's an amazing pennetrant.
    Good luck
