Hot Rods Ryan's Falcon - Young Gun's Straight Axle Build
Discussion in 'The Hokey Ass Message Board' started by Saxxon, Oct 28, 2017.
  1. Saxxon
    Saxxon
    When my Brother, his daughter Megan and I went to Meltdown 8 this summer we had Megan's boyfriend - Ryan - tag along and lend us his truck to help tow the Prefect. Well, not too surprising, the vintage bug bit Ryan hard. Well it just so happens my brother has had this beautifully preserved 63 Falcon street racer from the 70's that has been sitting in the shop for the last 10+ years. I had thought on building it but my Scout starting chewing up money and a 49 Austin truck came into the picture (but I digress) ...
    Ryan is very serious about this vintage stuff so he and my brother swung a really good deal for the Falcon. Ryan then picked up a rebuilt and warmed over 429 / C6 locally and ordered a 10 point cage and sub frame connectors from Jegs and a complete leaf spring 4" drop straight axle kit with a Vega box and disc brakes from Speedway - which showed up this week.
    The car will be race only but we are trying to keep a lot of the stock pieces intact - just in case. The interior panels are very good and the dash and gauge cluster is perfect. Seats will be fibergl*** race units. We are even considering keeping the back seat in place if possible. The rest of this car is pretty remarkable. There are a couple of rust spots in the uni-body that are easy fixes but for the most part this thing is very straight and very solid
    Today, 4 of us descended on the shop and started the build. By the end of day one, we have the front springs and axle mocked in, sub-frame connectors in place and we found a heavy duty 9" diff from a Bronco that is the perfect width and the existing spring pads lines up with the rear spring perfectly. The plan is use Cal-Tracs or a Slide-a-Link system. Anywhere we welded mounts or connections we added reinforcements to the frame. By end of day tomorrow we should have the front ***embled and the rear end and springs mocked up. We are also planning to have the cage started.
    Still a long way from done but we started with a solid car that was half dis***embled so we have a great start for this kid's race car project ... Ryan is pretty happy about it !!
    Scott welding in the sub frame connectors
    IMG_0419.JPG View attachment 3700339
    Pumped up car owner - Ryan
    10 Point cage resting on the bender we won't need to use
    IMG_0422.JPG View attachment 3700344
    cktasto, swade41, BradinNC and 16 others like this.
  2. Mike Colemire
    Mike Colemire
    This is going to be a cool build.
    Saxxon and loudbang like this.
  3. Looks like a good start, looking forward to see this progress
  4. Texas Webb
    Texas Webb
    Good you got another youngblood in the hobby.Sounds like a good project.
    loudbang and Saxxon like this.
  5. Jalopy Joker
    Jalopy Joker
    yes, you can tell by his eyes that he has that crazy hot rod/race car blood flowing in his veins - Cool project
    Saxxon, mad mikey and loudbang like this.
  6. Max Gearhead
    Max Gearhead
    from Wisconsin
  7. 56sedandelivery
    56sedandelivery
    Sounds like he got bit HARD! Good thing he was't allergic. 429 in a Falcon; I don't think Ford ever intended that to happen. There's a plainer looking 63 post, other than the standout paint job, running over at Bremerton Raceway with a 460/C6/9". Name escapes me, but it's fast. I am Butch/56sedandelivery.
    The name of that Falcon is "WILDTHING". Black with multicolored side stripes, and low to the ground; 60-63 style post car
  8. loudbang
    Be following this one :) ford power
  9. southcross2631
    southcross2631
    Like Falcon's and 429's. So it should be a good combination. A set of P-51 heads will be your best upgrade. Here's my old Falcon. 2013-10-10 11.55.36 (1).jpg
  10. mad mikey
    mad mikey
    Nice car! Keep it simple and fast. Great to see this one going racing.:D
  11. low budget
    low budget
    from Central Ky
    Like that particular look of the rear wheel well radiuses
  12. Hank37
    Hank37
    Whether on the strip or dirt track they look fast , keep up the good work young man ! DSC_0081.JPG
    pila38, quick85, Bugsy48 and 5 others like this.
  13. slowmotion
    slowmotion
    Way cool to see a young fella getting into this hobby, good for him. Those early Falcons make bad*** racecars. That one looks solid & well on it's way. Always handy to have a seasoned mentor around too.:D Good luck with it, it'll be fun watching this one develop.
    chryslerfan55, loudbang and Saxxon like this.
  14. Saxxon
    Saxxon
    There are plans to tie together the sub-frame connectors, cage plates, down bars, cross members and pretty much anything else that will add structure. Much in the same way the radial cars do it. In the end it will be a uni-body car with a frame (ish). The car will not be back halved. The plan is to run 28x10 slicks or Pie Crusts
    We haven't seen the 429 yet so we are taking Ryan's word (who took the seller's word) it's in good shape. For now the plan is to leave it the way it is unless there are some obvious updates we would recommend - like swapping a stock intake for alloy... The plan is to build fender-well headers but Plan-B is a set of Crites frame headers. What we don't know is what to do for mounts. I'm hoping there is a swap kit or aftermarket for the application. I'm promoting an engine plate but we are not afraid to build mounts either. Just cheaper and easier to buy what exists.
    Ryan is excited about this build. I had the talk with him about posting a picture of the look and stance and to write a plan that includes guidelines, goals, maybe an option or 2 and a budget - then stick to it !! We also told him before he buys anything to come ask us old guys about it. We have stuff stashed away that he will need. (Fuel pump, regulator, fittings, carbs etc) Paul and I have promised to not sway the build in our direction unless it's a safety issue or it's taking Ryan down a (costly & frustrating) path he won't enjoy. Unfortunately there will be a lot of folks and young (tuner car) friends who don't get it and will criticize choices like the straight axle vs. a Mustang II front...
  15. woodbutcher
    woodbutcher
    :D This looks like a load of fun.I`ll saddle up and go along for the ride.
    Good luck.Have fun.Be safe.
    Leo
  16. RmK57
    RmK57
    If the 429 your going to look at is a 1972 engine I would stay clear. The D2VE heads have around a 100 cc combustion chamber and really don't mix well for any performance use.
    Look for a 68-71 429-460.
  17. Saxxon
    Saxxon
    Unless there is something seriously wrong with the engine - the 429 is a done deal. We are familiar with the Ford. This is a purchase Ryan made on his own and we respect that. I'm hoping it's a decent long block that we can upgrade with a good hydraulic roller cam and a decent intake / carb combo. Guess we'll just have to see what it is and go from there
    chryslerfan55, wvenfield and loudbang like this.
  18. RmK57
    RmK57
  19. slowmotion
    slowmotion
    I like this^^^^^^^.
    Let 'em hang out a little like the old days.:D
  20. southcross2631
    southcross2631
    Go on 429- 460 .com and contact rpmcomprandy for one of his custom ground flat tappet cams. The price is reasonable and will make gobs of power.
    I am putting parts together to build 429 G***er motor with 440 Mopar rods and 460 pistons. I have a 429 Cobra Jet block and crank. They can be made to make stupid power with the right parts. The stock block and crank will take a ton of power and rpm's.
    scott27, enloe, GASSERBOB and 8 others like this.
  21. Saxxon
    Saxxon
    I missed the shop work today but the guys got the front and back hoops of the cage installed with the required floor plates. Shock towers are history and the front spindles are mocked in.
  22. Saxxon
    Saxxon
    For now the power levels of the 429 will likely be governed by how much Ryan is able to spend. We have more than a few BBF guys in our area who make solid and dependable combinations. We also use one of the best engine builders in Brazier Race and Machine. My guess is this will be a bolt on build to get it running. Still... with a healthy 429 with a good cam, intake, carb and headers should put this lightweight into the low 13's / high 12's ... All of which is speculation until Ryan brings it to the shop... which should be soon as mocking up the engine and trans could easily be the next step.
    chryslerfan55, loudbang and Gammz like this.
  23. Rye-guy
    Rye-guy
    IMG_0613.JPG IMG_0613.JPG IMG_0613.JPG IMG_0614.JPG IMG_0615.JPG IMG_0616.JPG IMG_0617.JPG IMG_0618.JPG IMG_0619.JPG IMG_0613.JPG IMG_0613.JPG Hi,
    I am the owner/driver of the car.
    Just updating the build.
    We got the motor and trans to the shop and I found out that I actually have the d0ve heads which is going to save me some money. As well as today we pretty much finished the cage minus the door bars which will be last as well we got the engine in the engine bay just to see clearance issues etc.
    We have come to the conclusion that the motor will actually be moved back about 4 inches, we are cutting out the firewall and moving it back and making it as part of the mid-plate that will also be put in.
    We will be putting in a removable tunnel to help with ease of removal of the trans if ever needed.
  24. saltflats
    saltflats
    from Missouri
    Looks like you are making good head way!!!
    Those DOVE heads should plant your *** firmly in the seat. ;)
    enloe, loudbang and chryslerfan55 like this.
  25. Gammz
    Gammz
    from Lincoln Ne
    "Head Way" SaltFlats is so clever!! [emoji23]
    loudbang and saltflats like this.
  26. saltflats
    saltflats
    from Missouri
    Just can't slip p*** you Gammz your to sharp.
    Did you try a fresh set of plug in the pie hauler yet?
  27. Gammz
    Gammz
    from Lincoln Ne
    Not yet. Soon very soon.
  28. Saxxon
    Saxxon
    I am letting Ryan take over on the updates. It's his car, his money being spent and it should be in his own words. In a weird way, posting updates here is incentive to a actually doing something worth posting.
    This build is pretty straight forward. Pieces and parts are readily available as packages and kits. The big block will make it different. Of course up here anything like this is different... It's great learning experience for Ryan, and a good reminder and practice for me.
    The cage is in and the serious welding is done - for now. The focus will be getting the engine and transmission in place. I was very happy to see that Ryan had his own opinions on what should be done and how it to do it. The mid plate had him spooked a bit as did the 4" set back. In reality we just wanted to add a 4" box into the firewall for engine and rad clearance. It was not to make a radical set back. The cage was installed 4" farther back than designed which provides room to move the seat back. This will still provide very good leg room even with the 4" firewall adjustment.
    I wish we had a picture when we threw a seat on the floor and had Ryan test fit. There are certain points in a build that should be remembered... first time pulled out of the field, first engine test fit, first seat test fit (with mandatory Vroom Vroom noises) first time on 4 wheels, first engine fire ... you get the idea
    Of course it's not officially a project until you bleed on it and set yourself on fire... maybe that's just me
  29. Rye-guy
    Rye-guy
    IMG_0640.JPG IMG_0641.JPG IMG_0644.JPG IMG_0645.JPG IMG_0646.JPG It's been a while since I've updated because progress has been slow but today it picked up again, the stock firewall is gone and the 4" box was made, the engine is almost done being put in, just need to weld in the side mounts, the car is actually coming together quite well I think, and quick which is what I want for it to be ready to race this spring
  30. loudbang
    Yea get it done we need more FOMOCO powered cars.
