s-10 frame in a 46 tudor sedan????
Discussion in 'The Hokey Ass Message Board' started by 46fordnewbie, Aug 24, 2009.
  1. 46fordnewbie
    46fordnewbie
    i was loking for a little info on putting a 46 ford tudor on an s-10 frame, tech info, pics anything would be apprciated. can't decide if i want to put a mustang II in it or the s-10.
    thanks :confused:
  2. plodge55aqua
    plodge55aqua
    from Alberta
    Hello, go to the search bar at the upper right.. s10 frame swaps.. theres a pile of pages for your info..
  3. plodge55aqua
    plodge55aqua
    from Alberta
  4. G V Gordon
    G V Gordon
    from Enid OK
    I know it gets badmouthed a lot but it makes a nice swap. Case in point. Biggest hassel is the forward mounted steering box.
  5. screwball
    screwball
    look up koolkemp hes doing a sedan as we speak.
  6. chris55
    chris55
    If you still have the 46 frame, you can clip the s-10 frame, and it will line right up at the fire wall.
  7. damm front mounted steering box. sure wish someone would build a reasonable r&p for s10. those ones that speedway sells are crazy $$$$:eek:!
  8. koolkemp
    koolkemp
    Hey GV do you know this car?? If so I was wondering if the s10 chassis has been modified with any lowering components or if its at "stock" ride hieght?
  9. koolkemp
    koolkemp
    Been workin on a 58 GMC for a friend, but its almost done. Gonna strip the rest of the s10 in the next 2 weeks and blast the frame ...then its cuttin and welding time!!
  10. G V Gordon
    G V Gordon
    from Enid OK
    Friends car. 2" lowering springs in the front. Stock s-10 rear suspension. I believe they had to shorten it a bit but not sure how much. The owner is Twisted Okie on the board. You can PM him but it may take a day or two to hear from him as he is not on the board every day.
  11. TexasHardcore
    TexasHardcore
    from Austin-ish
    When you do the S-10 frame swap, I'll come take the old '46 Frame off your hands.
  12. koolkemp
    koolkemp
    Thanks GV, I will get a PM off to him !
